Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Tools
Spudger4.9
Introduction
Go to step 1 ↓Over time, the battery can lose its capacity, causing the vacuum to require more frequent charging. If your robot vacuum struggles to hold a charge, acts strangely during cleaning, or doesn't run as long as it used to, these are signs that the battery could be worn out.
Generally, you may need to replace robot vacuum batteries every 1 to 3 years, depending on the type and how much you use it. Taking good care of your vacuum and following the manufacturer's recommendations can help the battery last longer, and newer battery technology offers more durable replacement options.
Use this guide to replace the battery for your Roborock Q5 robot vacuum.
Before starting this procedure, power off your device
Power off your Roborock and place the device on a flat surface with the wheels facing up.
Position the robot so the five-pronged side brush is on the bottom right side.
Use a Phillips screwdriver to remove the seven 15 mm screws from the bottom panel.
