Roccat Tyon omron switch Replacement
  1. Roccat Tyon omron switch Replacement, uncovering the screws: step 1, image 1 of 3 Roccat Tyon omron switch Replacement, uncovering the screws: step 1, image 2 of 3 Roccat Tyon omron switch Replacement, uncovering the screws: step 1, image 3 of 3
    • All screw are hidden below the mouse
    • Peel off the mouse pad to uncover 5 of the 6 screws
    • The last screw is in a hole under the sticker. You don't need to remove the whole sticker to uncover it.
  2. Roccat Tyon omron switch Replacement, remove the screws: step 2, image 1 of 2 Roccat Tyon omron switch Replacement, remove the screws: step 2, image 2 of 2
    • use the screwdriver to remove all the screws
  3. Roccat Tyon omron switch Replacement, separate the top half: step 3, image 1 of 2 Roccat Tyon omron switch Replacement, separate the top half: step 3, image 2 of 2
    • Carefully remove the outer shell, the two halves are still connected by wires.
    • remove the white wire connector carefully
  4. Roccat Tyon omron switch Replacement: step 4, image 1 of 3 Roccat Tyon omron switch Replacement: step 4, image 2 of 3 Roccat Tyon omron switch Replacement: step 4, image 3 of 3
    • unplug the remaining connectors
    • carefully pull-down the Ribbon cable to unplug it
  5. Roccat Tyon omron switch Replacement, free the PCB: step 5, image 1 of 3 Roccat Tyon omron switch Replacement, free the PCB: step 5, image 2 of 3 Roccat Tyon omron switch Replacement, free the PCB: step 5, image 3 of 3
    • remove the last screws and pull the board free
    • the mouse wheel LED assembly is a separate piece you need to unscrew.
  6. Roccat Tyon omron switch Replacement, remove the mouse wheel: step 6, image 1 of 2 Roccat Tyon omron switch Replacement, remove the mouse wheel: step 6, image 2 of 2
    • you need to pull the mouse wheel to the right to get it out
  7. Roccat Tyon omron switch Replacement, remove the old omron switch: step 7, image 1 of 2 Roccat Tyon omron switch Replacement, remove the old omron switch: step 7, image 2 of 2
    • I want to change the left switch.
    • flip the board to unsolder the switch.
    • Only two legs are soldered, this is the third one
  8. Roccat Tyon omron switch Replacement, solder the new switch: step 8, image 1 of 2 Roccat Tyon omron switch Replacement, solder the new switch: step 8, image 2 of 2
    • The new switch replace the old one not working.
    • The button should be on the left
    • I used a slightly different switch (D2FC-F-K(50M)). The official one is a D2FC-F-7N(RT)
7 other people completed this guide.
marc balemboy
417 Reputation
1 Guide authored
One Comment
Greetings,
Would you happen to know the part number for the x-celerator paddle potentiometer replacement?
Thanks!
Enrique Rumbo - Reply
Past 24 Hours: 6
Past 7 Days: 29
Past 30 Days: 85
All Time: 3,465
