Rocketfish RF-WSP313 Speaker Replacement
  1. Rocketfish RF-WSP313 Speaker Replacement, Speaker: step 1, image 1 of 1
    • Using the metal spudger, remove the outer cap from the top of the device.
  2. Rocketfish RF-WSP313 Speaker Replacement: step 2, image 1 of 1
    • Using a Phillips # 1 screwdriver, remove the four 1.1 cm flathead screws attaching the metal ring to the top of the device.
  3. Rocketfish RF-WSP313 Speaker Replacement: step 3, image 1 of 1
    • Remove the ring and set aside.
  4. Rocketfish RF-WSP313 Speaker Replacement: step 4, image 1 of 1
    • Using the metal spudger, remove the cap from the bottom of the device.
  5. Rocketfish RF-WSP313 Speaker Replacement: step 5, image 1 of 1
    • Using a Phillips # 1 screwdriver, remove the four 1.1 sm screws attaching the metal ring to the bottom of the device.
  6. Rocketfish RF-WSP313 Speaker Replacement: step 6, image 1 of 1
  7. Rocketfish RF-WSP313 Speaker Replacement: step 7, image 1 of 1
    • Using a Phillips # 1 screwdriver, remove the four 1 cm screws from the outside panel. You will do this for each panel; it does not matter which side you start with.
  8. Rocketfish RF-WSP313 Speaker Replacement: step 8, image 1 of 1
    • Using the metal spudger, pry off the side panel. Repeat this step on the other side panel.
  9. Rocketfish RF-WSP313 Speaker Replacement: step 9, image 1 of 1
    • Using a Phillips #1 screwdriver, remove the four 1.1 cm flathead screws from the side of the device. Repeat this step on the other side of the device.
  10. Rocketfish RF-WSP313 Speaker Replacement: step 10, image 1 of 2 Rocketfish RF-WSP313 Speaker Replacement: step 10, image 2 of 2
    • Using the metal spudger, open the device.
  11. Rocketfish RF-WSP313 Speaker Replacement: step 11, image 1 of 2 Rocketfish RF-WSP313 Speaker Replacement: step 11, image 2 of 2
    Tool used on this step:
    Buy
    • Using your fingers (or a pair of tweezers), disconnect the speaker cord from its socket.
  12. Rocketfish RF-WSP313 Speaker Replacement: step 12, image 1 of 1
    • Using a Phillips #1 screwdriver, remove the four 1.2 cm pan head screws surrounding the speaker.
  13. Rocketfish RF-WSP313 Speaker Replacement: step 13, image 1 of 1
    • Remove the speaker from the device.
Kara Falknor
101 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 21
All Time: 592
