Roku Streaming Stick Macro Button Contacts Replacement
  1. Roku Streaming Stick Macro Button Contacts Replacement, Macro Button Contacts: step 1, image 1 of 1
    • Place the remote so that the battery cover is facing upwards.
  2. Roku Streaming Stick Macro Button Contacts Replacement: step 2, image 1 of 1
    • Remove the battery cover to expose the battery compartment.
  3. Roku Streaming Stick Macro Button Contacts Replacement: step 3, image 1 of 1
    • Remove batteries.
  4. Roku Streaming Stick Macro Button Contacts Replacement: step 4, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the 1.5 mm wide screw.
  5. Roku Streaming Stick Macro Button Contacts Replacement: step 5, image 1 of 2 Roku Streaming Stick Macro Button Contacts Replacement: step 5, image 2 of 2
    • Use a plastic opening tool to gently pry apart the plastic enclosure. Make sure you create a large enough gap before you attempt to separate the two pieces.
  6. Roku Streaming Stick Macro Button Contacts Replacement: step 6, image 1 of 1
    • Gently remove the circuit board or motherboard.
  7. Roku Streaming Stick Macro Button Contacts Replacement: step 7, image 1 of 1
    • First, gently remove the three plastic sheets. Then, remove the button panels from the remote control.
    • Repair the contact sheet as noted on the Button Contact Repair Kit listed above. Otherwise replace with new conductive button contacts.
Feliciano Bandazi
145 Reputation
1 Guide authored
IUPUI, Team S2-G2, Wilson Spring 2018 Member of IUPUI, Team S2-G2, Wilson Spring 2018
IUPUI-WILSON-S18S2G2
4 Members
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 29
All Time: 3,804
