Roland G-800 Power Board Replacement
  1. Roland G-800 Power Board Replacement, Top cover: step 1, image 1 of 1
    • Turn the keyboard upside down to access the screws
    • Remove 15 Philips PH2 screws
    • Don't worry about the other 16 screws, they hold the keys to the bottom case.
  2. Roland G-800 Power Board Replacement: step 2, image 1 of 2 Roland G-800 Power Board Replacement: step 2, image 2 of 2
    • Turn the keyboard upright again and lift the top cover from the front
    • Remove 6 connectors
  3. Roland G-800 Power Board Replacement, Power Board: step 3, image 1 of 2 Roland G-800 Power Board Replacement, Power Board: step 3, image 2 of 2
    • Remove the power output connector
    • Take note of the order of the wires here. In this case we have the white (neutral) wire on the left, but always double check when working with mains wiring.
    • Loosen the two flathead screws holding the mains wires to release them
  4. Roland G-800 Power Board Replacement: step 4, image 1 of 1
    • Remove 4 PH2 screws holding the board to the case.
4 other people completed this guide.
Andrew
1,341 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 26
All Time: 1,882
