Roller Skate Double Action Cushion Replacement
  1. Roller Skate Double Action Cushion Replacement, Sure-Grip Double Action Cushion: step 1, image 1 of 1
    • Using a 14 mm wrench, loosen and extract the bolt from the base plate.
  2. Roller Skate Double Action Cushion Replacement: step 2, image 1 of 1
    • Once the bolt is no longer in the base plate, lift and twist the entire truck assembly from the skate.
  3. Roller Skate Double Action Cushion Replacement: step 3, image 1 of 2 Roller Skate Double Action Cushion Replacement: step 3, image 2 of 2
    • Flip the truck over and remove the nut from the truck assembly bolt.
  4. Roller Skate Double Action Cushion Replacement: step 4, image 1 of 2 Roller Skate Double Action Cushion Replacement: step 4, image 2 of 2
    • Remove both sets of cushions and retaining washers from the bolt.
  5. Roller Skate Double Action Cushion Replacement: step 5, image 1 of 3 Roller Skate Double Action Cushion Replacement: step 5, image 2 of 3 Roller Skate Double Action Cushion Replacement: step 5, image 3 of 3
    • Remove the retaining washer from each cushion.
    • Use a spudger if the washer and cushion are difficult to separate.
    • Replace worn cushions and washers.
Jen Rushing
1 Reputation
1 Guide authored
CCNTH Repair Project Member of CCNTH Repair Project
Community
2 Members
3 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 9
All Time: 2,122
