Rosewill NEON M62 Cable Replacement
  1. Rosewill NEON M62 Cable Replacement, Bottom Panel: step 1, image 1 of 1
    • Place the mouse so the bottom is facing upwards.
    • Remove the plastic skates.
    • These are not shown in the picture since they were missing from the device.
    • Remove the two 5 mm screws with a Phillips #00 screwdriver.
  2. Rosewill NEON M62 Cable Replacement: step 2, image 1 of 1
    • Use the opening tool along the side of the mouse to open up it.
    • This may take multiple attempts to do so; be patient and careful not to break the mouse.
  3. Rosewill NEON M62 Cable Replacement: step 3, image 1 of 2 Rosewill NEON M62 Cable Replacement: step 3, image 2 of 2
    • Loosen the top and bottom half of the mouse with the opening tool, and slowly pull up the bottom half of the mouse.
  4. Rosewill NEON M62 Cable Replacement, Cable: step 4, image 1 of 2 Rosewill NEON M62 Cable Replacement, Cable: step 4, image 2 of 2
    • Gently pull the cable toward yourself and around the right side, being careful not to damage the wires.
  5. Rosewill NEON M62 Cable Replacement: step 5, image 1 of 1
    Tool used on this step:
    Buy
    • Carefully, using your fingers or tweezers, pull the white connecter up.
    • Do not pull by the wires.
Julian Abraham
414 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 82
