Rosewill NEON M62 Scroll Wheel RGB Board Replacement
  1. Rosewill NEON M62 Scroll Wheel RGB Board Replacement, Bottom Panel: step 1, image 1 of 1
    • Place the mouse so the bottom is facing upwards.
    • Remove the plastic skates.
    • These are not shown in the picture since they were missing from the device.
    • Remove the two 5 mm screws with a Phillips #00 screwdriver.
  2. Rosewill NEON M62 Scroll Wheel RGB Board Replacement: step 2, image 1 of 1
    • Use the opening tool along the side of the mouse to open up it.
    • This may take multiple attempts to do so; be patient and careful not to break the mouse.
  3. Rosewill NEON M62 Scroll Wheel RGB Board Replacement: step 3, image 1 of 2 Rosewill NEON M62 Scroll Wheel RGB Board Replacement: step 3, image 2 of 2
    • Loosen the top and bottom half of the mouse with the opening tool, and slowly pull up the bottom half of the mouse.
  4. Rosewill NEON M62 Scroll Wheel RGB Board Replacement, Scroll Wheel RGB Board: step 4, image 1 of 2 Rosewill NEON M62 Scroll Wheel RGB Board Replacement, Scroll Wheel RGB Board: step 4, image 2 of 2
    • Use the opening tool to push the scroll wheel RGB board up and to the right until it disconnects.
Julian Abraham
414 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 7
All Time: 75
