Rosewill NEON M62 Scroll Wheel Replacement
  1. Rosewill NEON M62 Scroll Wheel Replacement, Bottom Panel: step 1, image 1 of 1
    • Place the mouse so the bottom is facing upwards.
    • Remove the plastic skates.
    • These are not shown in the picture since they were missing from the device.
    • Remove the two 5 mm screws with a Phillips #00 screwdriver.
  2. Rosewill NEON M62 Scroll Wheel Replacement: step 2, image 1 of 1
    • Use the opening tool along the side of the mouse to open up it.
    • This may take multiple attempts to do so; be patient and careful not to break the mouse.
  3. Rosewill NEON M62 Scroll Wheel Replacement: step 3, image 1 of 2 Rosewill NEON M62 Scroll Wheel Replacement: step 3, image 2 of 2
    • Loosen the top and bottom half of the mouse with the opening tool, and slowly pull up the bottom half of the mouse.
  4. Rosewill NEON M62 Scroll Wheel Replacement, Scroll Wheel RGB Board: step 4, image 1 of 2 Rosewill NEON M62 Scroll Wheel Replacement, Scroll Wheel RGB Board: step 4, image 2 of 2
    • Use the opening tool to push the scroll wheel RGB board up and to the right until it disconnects.
  5. Rosewill NEON M62 Scroll Wheel Replacement, Scroll Wheel: step 5, image 1 of 2 Rosewill NEON M62 Scroll Wheel Replacement, Scroll Wheel: step 5, image 2 of 2
    • Remove the four 5 mm screws from the motherboard using a Phillips #00 screwdriver.
    • Remove the board from the bottom of the mouse.
  6. Rosewill NEON M62 Scroll Wheel Replacement: step 6, image 1 of 2 Rosewill NEON M62 Scroll Wheel Replacement: step 6, image 2 of 2
    • Gently push the wheel up and to the right to remove it from the board.
Julian Abraham
414 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 17
All Time: 96
