Royal Sovereign Fan Replacement
  1. Royal Sovereign Fan Replacement, Fan: step 1, image 1 of 2 Royal Sovereign Fan Replacement, Fan: step 1, image 2 of 2
    • Make sure that the heater is unplugged and completely cooled down.
    • Turn the heater so the back is facing up.
    • Remove all six 14 mm screws using the Philips #0 screwdriver.
  2. Royal Sovereign Fan Replacement: step 2, image 1 of 1
    • Separate the back case from the heater.
  3. Royal Sovereign Fan Replacement: step 3, image 1 of 2 Royal Sovereign Fan Replacement: step 3, image 2 of 2
    • You are left with the motor and wires attached to the front case.
    • Use the Phillips #1 screwdriver to remove the four 14 mm screws attaching the motor to the front case..
    • Do not untangle the wires
  4. Royal Sovereign Fan Replacement: step 4, image 1 of 2 Royal Sovereign Fan Replacement: step 4, image 2 of 2
    • Turn the motor over to reveal the fan.
    • Use a plier to twist and unscrew the hexagonal screw attached to the fan.
  5. Royal Sovereign Fan Replacement: step 5, image 1 of 1
    • Take the fan out.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 27
All Time: 657
