Ruton Mixer Gear Replacement
  1. Ruton Mixer Gear Replacement, Gears: step 1, image 1 of 2 Ruton Mixer Gear Replacement, Gears: step 1, image 2 of 2
    • Slightly loosen all four 2.54 cm Phillips #1 screws and remove them.
    • Remove the top casing.
  2. Ruton Mixer Gear Replacement: step 2, image 1 of 2 Ruton Mixer Gear Replacement: step 2, image 2 of 2
    • Remove the button unit, including the spring.
  3. Ruton Mixer Gear Replacement: step 3, image 1 of 2 Ruton Mixer Gear Replacement: step 3, image 2 of 2
    • Remove the 1.50 cm Phillips #1 screw that holds the cable clamp.
    • Remove the cable clamp.
  4. Ruton Mixer Gear Replacement: step 4, image 1 of 1
    • Lift the product from the bottom casing.
  5. Ruton Mixer Gear Replacement: step 5, image 1 of 3 Ruton Mixer Gear Replacement: step 5, image 2 of 3 Ruton Mixer Gear Replacement: step 5, image 3 of 3
    • Lay the product on its side and remove the 1.27 cm Phillips #1 screw holding the bottom metal plate in place.
    • Remove the metal plate holding the gears in place.
  6. Ruton Mixer Gear Replacement: step 6, image 1 of 1
    • Remove the gears.
  7. Ruton Mixer Gear Replacement: step 7, image 1 of 2 Ruton Mixer Gear Replacement: step 7, image 2 of 2
    • Replace the gears with new ones.
  8. Ruton Mixer Gear Replacement: step 8, image 1 of 2 Ruton Mixer Gear Replacement: step 8, image 2 of 2
    • Reassemble the mixer.
    • Put the cable protection in the correct position before fastening the cable and reassembling the mixer.
2 Guide Comments
Hey, do you have a print file or do you know a place where i can buy these gears? Would really like to repair my own mixer.
Tibor Casteleijn - Reply
They can be bought from all kind of places, I'm on it as well now, refurbishing a vintage 60s handmixer.
I know some sellers need product serial number and if you don't have that (I don't) then it's more problematic.
Especially problematic if your device is older like mine.
What we need to find is a motor drive train cog gear manufacturer, that could produce custom made tailored, so we could send one gear wheel to them and they would produce.
Maybe there are 3D molding/printing services, as 3D printing is the standard today of so much?
Greets
Henry -
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 17
All Time: 809
