Ryobi CSB125 Trigger Replacement
  1. Ryobi CSB125 Trigger Replacement, Trigger: step 1, image 1 of 1
    • Place the saw down on a flat surface with the motor facing up.
    • Make sure that the saw is unplugged from any power source.
  2. Ryobi CSB125 Trigger Replacement: step 2, image 1 of 2 Ryobi CSB125 Trigger Replacement: step 2, image 2 of 2
    • Use the Phillips #2 screwdriver to remove the five M4x16mm screws.
  3. Ryobi CSB125 Trigger Replacement: step 3, image 1 of 1
    • Use the Phillips #2 screwdriver to remove the two M45x35mm screws.
  4. Ryobi CSB125 Trigger Replacement: step 4, image 1 of 1
    • Disconnect the two black wires by unscrewing them from the trigger switch using the Phillips #2 screwdriver.
  5. Ryobi CSB125 Trigger Replacement: step 5, image 1 of 1
    • Remove the trigger from the saw.
    • You may have to use the wire strippers to the copper on the new plug.
    • It is important that the wires are properly run in their tracks. Failure to do so could result in pinching a wire, which could damage the plug.
3 other people completed this guide.
Curtis Melo
1,093 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 687
