Introduction
If you need to replace the motor of the Ryobi CSB135L, you can access the motor by following this guide below.
Remove the three M4.5 x 35mm screws that hold the motor housing to the blade housing using a Phillips screwdriver.
Although not required for motor housing removal, the two M4 x 16 mm Phillips head screws must be removed for access to the top of the motor.
Almost done!
