Ryobi Compact 18 Volt Hammer Drill P214 Housing Assembly Replacement
  1. Ryobi Compact 18 Volt Hammer Drill P214 Housing Assembly Replacement, Battery: step 1, image 1 of 3 Ryobi Compact 18 Volt Hammer Drill P214 Housing Assembly Replacement, Battery: step 1, image 2 of 3 Ryobi Compact 18 Volt Hammer Drill P214 Housing Assembly Replacement, Battery: step 1, image 3 of 3
    • Detach the battery unit from the drill body and pull the battery outwards.
    • If the battery doesn't disconnect easily, gently wiggle the battery back and forth until it comes out.
  2. Ryobi Compact 18 Volt Hammer Drill P214 Housing Assembly Replacement, Housing Assembly: step 2, image 1 of 1
    • Remove ten 13.5 mm screws from the drill casing using a Phillips #2 screwdriver to gain access to the interior.
  3. Ryobi Compact 18 Volt Hammer Drill P214 Housing Assembly Replacement: step 3, image 1 of 3 Ryobi Compact 18 Volt Hammer Drill P214 Housing Assembly Replacement: step 3, image 2 of 3 Ryobi Compact 18 Volt Hammer Drill P214 Housing Assembly Replacement: step 3, image 3 of 3
    • Grab the sides of the housing and pull straight up until the housing pulls away revealing the inside assembly.
0 Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 13
All Time: 137
