Ryobi Compact 18 Volt Hammer Drill P214 Trigger Replacement
  1. Ryobi Compact 18 Volt Hammer Drill P214 Trigger Replacement, Battery: step 1, image 1 of 3 Ryobi Compact 18 Volt Hammer Drill P214 Trigger Replacement, Battery: step 1, image 2 of 3 Ryobi Compact 18 Volt Hammer Drill P214 Trigger Replacement, Battery: step 1, image 3 of 3
    • Detach the battery unit from the drill body and pull the battery outwards.
    • If the battery doesn't disconnect easily, gently wiggle the battery back and forth until it comes out.
  2. Ryobi Compact 18 Volt Hammer Drill P214 Trigger Replacement, Housing Assembly: step 2, image 1 of 1
    • Remove ten 13.5 mm screws from the drill casing using a Phillips #2 screwdriver to gain access to the interior.
  3. Ryobi Compact 18 Volt Hammer Drill P214 Trigger Replacement: step 3, image 1 of 3 Ryobi Compact 18 Volt Hammer Drill P214 Trigger Replacement: step 3, image 2 of 3 Ryobi Compact 18 Volt Hammer Drill P214 Trigger Replacement: step 3, image 3 of 3
    • Grab the sides of the housing and pull straight up until the housing pulls away revealing the inside assembly.
  4. Ryobi Compact 18 Volt Hammer Drill P214 Trigger Replacement, Trigger: step 4, image 1 of 3 Ryobi Compact 18 Volt Hammer Drill P214 Trigger Replacement, Trigger: step 4, image 2 of 3 Ryobi Compact 18 Volt Hammer Drill P214 Trigger Replacement, Trigger: step 4, image 3 of 3
    • Gently lift the battery clip to gain access to the trigger.
    • You can now clean any debris blocking the trigger.
Robert Campbell
73 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 12
All Time: 211
