Ryobi P202 Battery Contacts Replacement
  1. Ryobi P202 Battery Contacts Replacement, Battery: step 1, image 1 of 3 Ryobi P202 Battery Contacts Replacement, Battery: step 1, image 2 of 3 Ryobi P202 Battery Contacts Replacement, Battery: step 1, image 3 of 3
    • The battery can shock you. Only touch plastic, non-conductive components.
    • Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards.
  2. Ryobi P202 Battery Contacts Replacement, Right Side Case: step 2, image 1 of 2 Ryobi P202 Battery Contacts Replacement, Right Side Case: step 2, image 2 of 2
    • Use a Torx T10 screw driver to unscrew all ten 13.5 mm screws from the drill casing to gain access to the interior.
  3. Ryobi P202 Battery Contacts Replacement: step 3, image 1 of 2 Ryobi P202 Battery Contacts Replacement: step 3, image 2 of 2
    • Gently lift the casing from the drill body.
    • Take the casing completely off the drill body to gain access to the interior of the drill.
    • The Ryobi P202 casing has Part #: 200690001
  4. Ryobi P202 Battery Contacts Replacement, Battery Contacts: step 4, image 1 of 2 Ryobi P202 Battery Contacts Replacement, Battery Contacts: step 4, image 2 of 2
    • Grip the battery clip and pull straight up to remove the metal battery contacts.
    • You can now clean the metal battery contacts with isopropyl alcohol.
Joseph Eckstein
1,596 Reputation
9 Guides authored
Cal Poly, Team 17-6, Forte Spring 2015 Member of Cal Poly, Team 17-6, Forte Spring 2015
CPSU-FORTE-S15S17G6
4 Members
10 Guides authored
4 Guide Comments
You don't really need to take apart the drill. You can clean the contacts with Qtips by reaching into cavity. Use rubbing alcohol and long Qtips. Also you can bend the contacts back to normal with a pair of needle nose plyers.
TheAarowsmith - Reply
Doe anyone know where I can buy new battery contacts as mine has snapped?
dsstirrup - Reply
Re snapped contacts, I’ve found this part no. but no supplier yet:
“Ryobi Contact Plate holder 300001044”
Jeremy Twiggs - Reply
Does anybody out there know where to find these as mine has snapped also, not ready to junk it out yet.
Kevin Kleckner - Reply
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 42
All Time: 4,707
