Ryobi P235 Direction of Rotation Selector Replacement
  1. Ryobi P235 Direction of Rotation Selector Replacement, Battery: step 1, image 1 of 2 Ryobi P235 Direction of Rotation Selector Replacement, Battery: step 1, image 2 of 2
    • Push in both push tabs on the battery at the same time.
    • They are located below the green housing and are in the middle on both sides of the battery.
  2. Ryobi P235 Direction of Rotation Selector Replacement: step 2, image 1 of 2 Ryobi P235 Direction of Rotation Selector Replacement: step 2, image 2 of 2
    • Pull the battery away from the drill housing while holding in both tabs.
  3. Ryobi P235 Direction of Rotation Selector Replacement, Direction of Rotation Selector: step 3, image 1 of 2 Ryobi P235 Direction of Rotation Selector Replacement, Direction of Rotation Selector: step 3, image 2 of 2
    • Use a Phillips #2 screwdriver to remove the eight 16 mm screws that secure the housing.
  4. Ryobi P235 Direction of Rotation Selector Replacement: step 4, image 1 of 2 Ryobi P235 Direction of Rotation Selector Replacement: step 4, image 2 of 2
    • Use a T20 Torx screwdriver to remove the four 25.4 mm screws that secure the front of the housing.
  5. Ryobi P235 Direction of Rotation Selector Replacement: step 5, image 1 of 2 Ryobi P235 Direction of Rotation Selector Replacement: step 5, image 2 of 2
    • Open the housing with the data label facing up.
  6. Ryobi P235 Direction of Rotation Selector Replacement: step 6, image 1 of 2 Ryobi P235 Direction of Rotation Selector Replacement: step 6, image 2 of 2
    • Lift the internal components out of the housing.
  7. Ryobi P235 Direction of Rotation Selector Replacement: step 7, image 1 of 2 Ryobi P235 Direction of Rotation Selector Replacement: step 7, image 2 of 2
    • Remove the gray plastic forward/reverse selector.
Justin Godleski
319 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 31
All Time: 1,077
