Ryobi P235 Trigger Replacement
  1. Ryobi P235 Trigger Replacement, Battery: step 1, image 1 of 2 Ryobi P235 Trigger Replacement, Battery: step 1, image 2 of 2
    • Push in both push tabs on the battery at the same time.
    • They are located below the green housing and are in the middle on both sides of the battery.
  2. Ryobi P235 Trigger Replacement: step 2, image 1 of 2 Ryobi P235 Trigger Replacement: step 2, image 2 of 2
    • Pull the battery away from the drill housing while holding in both tabs.
  3. Ryobi P235 Trigger Replacement, Trigger: step 3, image 1 of 2 Ryobi P235 Trigger Replacement, Trigger: step 3, image 2 of 2
    • Use a Phillips #2 screwdriver to remove the eight 16 mm screws that secure the housing.
  4. Ryobi P235 Trigger Replacement: step 4, image 1 of 2 Ryobi P235 Trigger Replacement: step 4, image 2 of 2
    • Use a T20 Torx screwdriver to remove the four 25.4 mm screws that secure the front of the housing.
  5. Ryobi P235 Trigger Replacement: step 5, image 1 of 2 Ryobi P235 Trigger Replacement: step 5, image 2 of 2
    • Open the housing with the data label facing up.
  6. Ryobi P235 Trigger Replacement: step 6, image 1 of 2 Ryobi P235 Trigger Replacement: step 6, image 2 of 2
    • Lift the trigger mechanism and other internal components out of the housing assembly.
  7. Ryobi P235 Trigger Replacement: step 7, image 1 of 3 Ryobi P235 Trigger Replacement: step 7, image 2 of 3 Ryobi P235 Trigger Replacement: step 7, image 3 of 3
    • Use a soldering iron to remove the black and red wires connecting the trigger assembly to the motor.
    • Use the soldering iron to connect the new trigger assembly to the motor.
    • Make sure the red wire connects to the lead with the red mark on it.
To reassemble your device, follow these instructions in reverse order starting at step 6.
3 other people completed this guide.
Paul Sousa
817 Reputation
5 Guides authored
1 Guide Comment
Is the trigger what makes this a brushless motor? Is it possible for the trigger to cause the battery to drain down completely overnight?
Netgazer - Reply Share
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 33
All Time: 2,016
