Ryobi P271 Reverse Switch Replacement
  1. Ryobi P271 Reverse Switch Replacement, Battery: step 1, image 1 of 3 Ryobi P271 Reverse Switch Replacement, Battery: step 1, image 2 of 3 Ryobi P271 Reverse Switch Replacement, Battery: step 1, image 3 of 3
    • Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards.
  2. Ryobi P271 Reverse Switch Replacement, Reverse Switch: step 2, image 1 of 1
    • Remove all ten Torx screws from the drill's case.
  3. Ryobi P271 Reverse Switch Replacement: step 3, image 1 of 1
    • Gently pull the casing apart.
    • Separating the casing too quickly could cause internals to become loose, and not easily seat together upon reassembly.
  4. Ryobi P271 Reverse Switch Replacement: step 4, image 1 of 1
    • Remove the trigger so that it can fully expose the reverse switch.
  5. Ryobi P271 Reverse Switch Replacement: step 5, image 1 of 1
    • Firmly grab the reverse switch and pull on it until it comes out of its socket.
nathan krehbiel
229 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 32
All Time: 1,314
