Ryobi P271 Trigger Replacement
  1. Ryobi P271 Trigger Replacement, Battery: step 1, image 1 of 3 Ryobi P271 Trigger Replacement, Battery: step 1, image 2 of 3 Ryobi P271 Trigger Replacement, Battery: step 1, image 3 of 3
    • Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards.
  2. Ryobi P271 Trigger Replacement, Trigger: step 2, image 1 of 1
    • Remove the screws from the drill's casing to gain access to the interior.
  3. Ryobi P271 Trigger Replacement: step 3, image 1 of 1
    • Lift and remove the casing off of the drill body.
  4. Ryobi P271 Trigger Replacement: step 4, image 1 of 1
    • Carefully lift and remove the battery clip, trigger, motor, and everything connected to the wires and pull straight out of the drill.
  5. Ryobi P271 Trigger Replacement: step 5, image 1 of 1
    • Separate the wiring from the trigger and the motor using a soldering iron and them replace them with a new trigger and motor by soldering the wires back together.
    • Follow this guide for soldering tips.
nathan krehbiel
229 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 682
