Ryobi P501G Motor Replacement
  1. Ryobi P501G Motor Replacement, Motor: step 1, image 1 of 1
    • Locate the screws at the top face of the saw, on the green plastic surface covering.
  2. Ryobi P501G Motor Replacement: step 2, image 1 of 2 Ryobi P501G Motor Replacement: step 2, image 2 of 2
    • Locate the eight outer screws of the plastic green encasement. They are marked in red in the picture.
    • Using a T15 torx screwdriver, unscrew all the holes, taking care not to lose any!
  3. Ryobi P501G Motor Replacement: step 3, image 1 of 2 Ryobi P501G Motor Replacement: step 3, image 2 of 2
    • Open up the top side of the encasement to reveal the internal parts of the saw.
    • Locate the motor.
  4. Ryobi P501G Motor Replacement: step 4, image 1 of 2 Ryobi P501G Motor Replacement: step 4, image 2 of 2
    • Using the T15 torx screwdriver, unscrew all four of the screws to free the motor from the encasement.
  5. Ryobi P501G Motor Replacement: step 5, image 1 of 1
    • Remove the motor and replace with a new one if needed.
    • Be careful when handling the motor- it may be very dirty/greasy. You might want to wear gloves for this step!
Sophia Arias
255 Reputation
2 Guides authored
Cal Poly, Team S1-G2, Maness Spring 2019 Member of Cal Poly, Team S1-G2, Maness Spring 2019
CPSU-MANESS-S19S1G2
4 Members
7 Guides authored
1 Guide Comment
Where can I find Ryobi circular saw motor Part #206216001? Thanks.
De-Hong Tang - Reply Share
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 25
All Time: 2,471
