Ryobi P501G Shell Replacement
  1. Ryobi P501G Shell Replacement, Blade: step 1, image 1 of 1
    • Locate the area where the blade is connected to the motor, where the circular covering is on the Ryobi P501G.
  2. Ryobi P501G Shell Replacement: step 2, image 1 of 2 Ryobi P501G Shell Replacement: step 2, image 2 of 2
    • Unscrew clockwise and remove the bearing in the middle, connecting the blade to the motor. This will also allow removal of the blade guard.
  3. Ryobi P501G Shell Replacement: step 3, image 1 of 3 Ryobi P501G Shell Replacement: step 3, image 2 of 3 Ryobi P501G Shell Replacement: step 3, image 3 of 3
    • Remove the four black screws holding the black bearing and remove the bearing itself.
  4. Ryobi P501G Shell Replacement: step 4, image 1 of 1
    • Once the black bearing is off, remove the transparent cover of the blade.
    • Once the cover is off, remove the blade.
    • Place the new blade with the flat notches lined up with the flat notches on the motor axle.
  5. Ryobi P501G Shell Replacement, Shell: step 5, image 1 of 3 Ryobi P501G Shell Replacement, Shell: step 5, image 2 of 3 Ryobi P501G Shell Replacement, Shell: step 5, image 3 of 3
    • Remove the three screws on the inside base of the metal casing of the blade.
    • Pull the metal blade casing off of the Ryobi P501G body.
  6. Ryobi P501G Shell Replacement: step 6, image 1 of 3 Ryobi P501G Shell Replacement: step 6, image 2 of 3 Ryobi P501G Shell Replacement: step 6, image 3 of 3
    • Remove all of the screws located on the right side of the saw.
    • Separate the right side of the saw from the left side by pulling away once all of the screws are removed.
    • Pull back the shell to access the housed parts underneath.
Eeshan Mishra
424 Reputation
4 Guides authored
Cal Poly, Team S1-G2, Maness Spring 2019 Member of Cal Poly, Team S1-G2, Maness Spring 2019
CPSU-MANESS-S19S1G2
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 330
