Ryobi P501G Trigger Replacement
  1. Ryobi P501G Trigger Replacement, Shell: step 1, image 1 of 3 Ryobi P501G Trigger Replacement, Shell: step 1, image 2 of 3 Ryobi P501G Trigger Replacement, Shell: step 1, image 3 of 3
    • Remove the three screws on the inside base of the metal casing of the blade.
    • Pull the metal blade casing off of the Ryobi P501G body.
  2. Ryobi P501G Trigger Replacement: step 2, image 1 of 3 Ryobi P501G Trigger Replacement: step 2, image 2 of 3 Ryobi P501G Trigger Replacement: step 2, image 3 of 3
    • Remove all of the screws located on the right side of the saw.
    • Separate the right side of the saw from the left side by pulling away once all of the screws are removed.
    • Pull back the shell to access the housed parts underneath.
  3. Ryobi P501G Trigger Replacement, Trigger: step 3, image 1 of 1
    • After opening the shell, locate the black plastic trigger on the handle of the device.
  4. Ryobi P501G Trigger Replacement: step 4, image 1 of 1
    • Remove the black wiring and the trigger is free! Reposition it however you'd like or switch it out with a new one.
    • Make sure the trigger is snug and exactly where you want it. A dislodged trigger can be very dangerous in a power saw!
Sophia Arias
255 Reputation
2 Guides authored
Cal Poly, Team S1-G2, Maness Spring 2019 Member of Cal Poly, Team S1-G2, Maness Spring 2019
CPSU-MANESS-S19S1G2
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 1,681
