Ryobi P516 Top Case Replacement
  1. Ryobi P516 Top Case Replacement, Top Case: step 1, image 1 of 2 Ryobi P516 Top Case Replacement, Top Case: step 1, image 2 of 2
    • Using the 5mm hex key included at the base of the saw, loosen the set screw at the front of the saw.
    • The front guard will now slide out from the front of the saw.
  2. Ryobi P516 Top Case Replacement: step 2, image 1 of 3 Ryobi P516 Top Case Replacement: step 2, image 2 of 3 Ryobi P516 Top Case Replacement: step 2, image 3 of 3
    • Remove the two 10mm T20 Torx screws from the front of the saw.
    • Pull out the front plate.
  3. Ryobi P516 Top Case Replacement: step 3, image 1 of 3 Ryobi P516 Top Case Replacement: step 3, image 2 of 3 Ryobi P516 Top Case Replacement: step 3, image 3 of 3
    • Start at the middle of the device and begin to pry up the rubber grip.
    • Pull the rubber portion inside out towards the front of the saw.
  4. Ryobi P516 Top Case Replacement: step 4, image 1 of 1
    • Remove all twelve 14mm T20 Torx screws from the main case of the device.
  5. Ryobi P516 Top Case Replacement: step 5, image 1 of 3 Ryobi P516 Top Case Replacement: step 5, image 2 of 3 Ryobi P516 Top Case Replacement: step 5, image 3 of 3
    • Remove the four 35mm Phillips #2 screws.
    • Pry the two case halves apart starting at the middle of the saw.
    • Watch out for any loose parts from inside the saw that may fall out during this step.
  6. Ryobi P516 Top Case Replacement: step 6, image 1 of 1
    • Continue splitting the case until the top piece of the case is free and set it aside.
6 other people completed this guide.
2 Comments
P516 blade locking parts
Bill clark - Reply
P516 blade locking parts breakdown, please ?
Bill clark - Reply
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 78
All Time: 4,330
