Ryobi RJ1861V Motor Housing Replacement
  1. Ryobi RJ1861V Motor Housing Replacement, Saw Bar Assembly: step 1, image 1 of 1
    • Use a Torx T5 screwdriver to remove the single 8 mm screw securing the shoe.
  2. Ryobi RJ1861V Motor Housing Replacement: step 2, image 1 of 2 Ryobi RJ1861V Motor Housing Replacement: step 2, image 2 of 2
    • Remove the rubber sleeve.
    • You may have to use some force as it has a tight fit.
  3. Ryobi RJ1861V Motor Housing Replacement: step 3, image 1 of 1
    • Use a Torx T5 screwdriver to remove the six screws on the underside of the device.
  4. Ryobi RJ1861V Motor Housing Replacement: step 4, image 1 of 1
    • Use a Torx T5 screwdriver to remove the four screws on the top of the gear case.
    • There are two screws on each side of the device.
  5. Ryobi RJ1861V Motor Housing Replacement: step 5, image 1 of 1
    • Remove the backside panel.
  6. Ryobi RJ1861V Motor Housing Replacement: step 6, image 1 of 1
    • Unscrew the four T5 Torx screws that hold the assembly bar in place.
  7. Ryobi RJ1861V Motor Housing Replacement: step 7, image 1 of 1
    • Lift the assembly bar up and out of the chassis.
  8. Ryobi RJ1861V Motor Housing Replacement, Assembly Bar Bearing: step 8, image 1 of 1
    • Begin with the top of the device facing up.
  9. Ryobi RJ1861V Motor Housing Replacement: step 9, image 1 of 1
    • Insert needle nose pliers to remove the retaining pin at the top of the bearing.
  10. Ryobi RJ1861V Motor Housing Replacement: step 10, image 1 of 1
    • Once the retaining pin has been removed, pull off the damaged bearing and insert a new one.
  11. Ryobi RJ1861V Motor Housing Replacement, Motor Housing: step 11, image 1 of 2 Ryobi RJ1861V Motor Housing Replacement, Motor Housing: step 11, image 2 of 2
    • After following prerequisite guides to get to the presented step, remove motor assembly from back housing.
    • Motor Assembly will be greasy
    • Motor Assembly
    • Motor Assembly Housing
  12. Ryobi RJ1861V Motor Housing Replacement: step 12, image 1 of 1
    • Using pliers to grab onto the elongated aluminium exterior of the housing, begin to slowly wiggle the motor assembly housing until it comes loose.
  13. Ryobi RJ1861V Motor Housing Replacement: step 13, image 1 of 1
    • Detach red wires from base of the back of the housing .
  14. Ryobi RJ1861V Motor Housing Replacement: step 14, image 1 of 1
    • After the wires have been detached it should be relatively easy to remove and replace the Motor Assembly Housing
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 10
All Time: 86
