Ryobi RS290G Brush Assembly Replacement
  1. Ryobi RS290G Brush Assembly Replacement, Top Cap: step 1, image 1 of 1
    • Remove two 20mm and one 16mm Phillips #2 screws from the housing assembly and exhaust port.
  2. Ryobi RS290G Brush Assembly Replacement: step 2, image 1 of 1
    • Remove the three 16mm Phillips #2 screws from the top cap/upper grip.
  3. Ryobi RS290G Brush Assembly Replacement: step 3, image 1 of 1
    • Remove the top cap.
  4. Ryobi RS290G Brush Assembly Replacement, Switch Trigger: step 4, image 1 of 1
    • Remove the switch trigger.
  5. Ryobi RS290G Brush Assembly Replacement, Brush Assembly: step 5, image 1 of 2 Ryobi RS290G Brush Assembly Replacement, Brush Assembly: step 5, image 2 of 2
    • Slide the power switch out of the housing assembly by carefully gripping the power switch and slide upward from the base.
  6. Ryobi RS290G Brush Assembly Replacement: step 6, image 1 of 1
    • Remove the two 16mm Phillips #2 screws from the inner housing assembly.
  7. Ryobi RS290G Brush Assembly Replacement: step 7, image 1 of 1
    • Remove the two 14mm Phillips #2 screws from the cord clamp.
  8. Ryobi RS290G Brush Assembly Replacement: step 8, image 1 of 1
    • Carefully slide the housing assembly apart, avoiding damage or pulling on wires.
  9. Ryobi RS290G Brush Assembly Replacement: step 9, image 1 of 2 Ryobi RS290G Brush Assembly Replacement: step 9, image 2 of 2
    • Slide out both brush assemblies from the inner housing assembly.
  10. Ryobi RS290G Brush Assembly Replacement: step 10, image 1 of 1
    • Slide off the disconnect terminal for the brush assembly (white lead).
  11. Ryobi RS290G Brush Assembly Replacement: step 11, image 1 of 1
    • Slide off the disconnect terminal for the brush assembly (black lead).
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 16
All Time: 759
