Ryobi RS290G Motor Replacement
  1. Ryobi RS290G Motor Replacement, Top Cap: step 1, image 1 of 1
    • Remove two 20mm and one 16mm Phillips #2 screws from the housing assembly and exhaust port.
  2. Ryobi RS290G Motor Replacement: step 2, image 1 of 1
    • Remove the three 16mm Phillips #2 screws from the top cap/upper grip.
  3. Ryobi RS290G Motor Replacement: step 3, image 1 of 1
    • Remove the top cap.
  4. Ryobi RS290G Motor Replacement, Switch Trigger: step 4, image 1 of 1
    • Remove the switch trigger.
  5. Ryobi RS290G Motor Replacement, Motor: step 5, image 1 of 1
    • Remove the two 16mm Phillips #2 screws from the inner housing assembly.
  6. Ryobi RS290G Motor Replacement: step 6, image 1 of 1
    • Remove the two 14mm Phillips #2 screws from the cord clamp.
  7. Ryobi RS290G Motor Replacement: step 7, image 1 of 2 Ryobi RS290G Motor Replacement: step 7, image 2 of 2
    • Slide the power switch out of the housing assembly.
  8. Ryobi RS290G Motor Replacement: step 8, image 1 of 1
    • Carefully slide the housing assembly apart, avoiding damage or pulling on wires.
  9. Ryobi RS290G Motor Replacement: step 9, image 1 of 2 Ryobi RS290G Motor Replacement: step 9, image 2 of 2
    • Slide off the disconnect terminal for the switch (red lead) from the power switch using the flat end of a spudger.
  10. Ryobi RS290G Motor Replacement: step 10, image 1 of 2 Ryobi RS290G Motor Replacement: step 10, image 2 of 2
    • Slide out the brush assembly with the black lead from the inner housing assembly.
  11. Ryobi RS290G Motor Replacement: step 11, image 1 of 1
    • Slide off the disconnect terminal for the brush assembly (black lead) from the brush assembly.
    • You may need an ESD-safe flat edge tool, such as a spudger, to help slide off the disconnect terminal. Be careful not to damage the pieces or yourself.
  12. Ryobi RS290G Motor Replacement: step 12, image 1 of 1
    • Remove the armature assembly, with the motor, out of the inner housing assembly.
  13. Ryobi RS290G Motor Replacement: step 13, image 1 of 3 Ryobi RS290G Motor Replacement: step 13, image 2 of 3 Ryobi RS290G Motor Replacement: step 13, image 3 of 3
    • Replace the motor (also known as field assembly).
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 18
All Time: 957
