Ryobi RS290G Power Switch Replacement
  1. Ryobi RS290G Power Switch Replacement, Top Cap: step 1, image 1 of 1
    • Remove two 20mm and one 16mm Phillips #2 screws from the housing assembly and exhaust port.
  2. Ryobi RS290G Power Switch Replacement: step 2, image 1 of 1
    • Remove the three 16mm Phillips #2 screws from the top cap/upper grip.
  3. Ryobi RS290G Power Switch Replacement: step 3, image 1 of 1
    • Remove the top cap.
  4. Ryobi RS290G Power Switch Replacement, Switch Trigger: step 4, image 1 of 1
    • Remove the switch trigger.
  5. Ryobi RS290G Power Switch Replacement, Power Switch: step 5, image 1 of 2 Ryobi RS290G Power Switch Replacement, Power Switch: step 5, image 2 of 2
    • Slide the power switch out of the housing assembly by carefully gripping the power switch and sliding upward from the base.
  6. Ryobi RS290G Power Switch Replacement: step 6, image 1 of 3 Ryobi RS290G Power Switch Replacement: step 6, image 2 of 3 Ryobi RS290G Power Switch Replacement: step 6, image 3 of 3
    • Slide the red and black leads from the power switch using a spudger.
To reassemble your device, follow these instructions in reverse order. After reassembling, perform an operational check before using.
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 5
All Time: 878
