Ryobi String Trimmer RY253SS Fuel Lines and Filter Replacement
  1. Ryobi String Trimmer RY253SS Fuel Lines and Filter Replacement, Fuel Lines and Filter: step 1, image 1 of 3 Ryobi String Trimmer RY253SS Fuel Lines and Filter Replacement, Fuel Lines and Filter: step 1, image 2 of 3 Ryobi String Trimmer RY253SS Fuel Lines and Filter Replacement, Fuel Lines and Filter: step 1, image 3 of 3
    • With your hands, remove the air filter cover from your edge trimmer.
    • This will expose the air filter and the screws that attach the housing to the frame.
    • Remove the air filter before moving to the next step.
  2. Ryobi String Trimmer RY253SS Fuel Lines and Filter Replacement: step 2, image 1 of 3 Ryobi String Trimmer RY253SS Fuel Lines and Filter Replacement: step 2, image 2 of 3 Ryobi String Trimmer RY253SS Fuel Lines and Filter Replacement: step 2, image 3 of 3
    • Remove the two M5 x 45 mm shoulder screws attaching the air filter housing to the engine frame using a flathead screwdriver.
    • Pull the housing away from the engine block.
    • The screws also attach the carburetor to the frame.
  3. Ryobi String Trimmer RY253SS Fuel Lines and Filter Replacement: step 3, image 1 of 2 Ryobi String Trimmer RY253SS Fuel Lines and Filter Replacement: step 3, image 2 of 2
    • Pull the carburetor away from the engine block.
    • Gently remove the input fuel line from the carburetor.
    • Gently remove the output fuel line from the carburetor.
  4. Ryobi String Trimmer RY253SS Fuel Lines and Filter Replacement: step 4, image 1 of 3 Ryobi String Trimmer RY253SS Fuel Lines and Filter Replacement: step 4, image 2 of 3 Ryobi String Trimmer RY253SS Fuel Lines and Filter Replacement: step 4, image 3 of 3
    • Use the cutting pliers to cut the excess line flush to the tank.
    • Use a screwdriver to push the remaining line into the tank.
  5. Ryobi String Trimmer RY253SS Fuel Lines and Filter Replacement: step 5, image 1 of 3 Ryobi String Trimmer RY253SS Fuel Lines and Filter Replacement: step 5, image 2 of 3 Ryobi String Trimmer RY253SS Fuel Lines and Filter Replacement: step 5, image 3 of 3
    • The lines should now be in the tank.
    • Lift and shake the edge trimmer until both lines fall out of the tank.
  6. Ryobi String Trimmer RY253SS Fuel Lines and Filter Replacement: step 6, image 1 of 2 Ryobi String Trimmer RY253SS Fuel Lines and Filter Replacement: step 6, image 2 of 2
    • Thread the gripping tool through the input line on the tank.
    • Thread the tool through the gas cap opening.
  7. Ryobi String Trimmer RY253SS Fuel Lines and Filter Replacement: step 7, image 1 of 2 Ryobi String Trimmer RY253SS Fuel Lines and Filter Replacement: step 7, image 2 of 2
    • Use the cutting pliers to taper the end of the fuel line.
    • A larger taper will make it easier to thread the fuel line through the hole in the tank.
  8. Ryobi String Trimmer RY253SS Fuel Lines and Filter Replacement: step 8, image 1 of 2 Ryobi String Trimmer RY253SS Fuel Lines and Filter Replacement: step 8, image 2 of 2
    • Insert the hooked end of the gripping tool into the fuel line.
    • Clamp the hook to avoid puncturing the tube or the gas tank when pulling it through.
  9. Ryobi String Trimmer RY253SS Fuel Lines and Filter Replacement: step 9, image 1 of 3 Ryobi String Trimmer RY253SS Fuel Lines and Filter Replacement: step 9, image 2 of 3 Ryobi String Trimmer RY253SS Fuel Lines and Filter Replacement: step 9, image 3 of 3
    • Lubricate the fuel line with the 2-Cycle oil.
    • The 2-Cycle Oil will more easily allow the fuel line to move through the hole in the gas tank.
    • Only use proper 2-Cycle oil to avoid contamination of the fuel tank.
  10. Ryobi String Trimmer RY253SS Fuel Lines and Filter Replacement: step 10, image 1 of 3 Ryobi String Trimmer RY253SS Fuel Lines and Filter Replacement: step 10, image 2 of 3 Ryobi String Trimmer RY253SS Fuel Lines and Filter Replacement: step 10, image 3 of 3
    • Place your finger through the key ring end of the gripping tool.
    • Pull the tool until the line begins to make its way through the hole.
    • Grab the fuel line directly with your hand to continue pulling it completely through.
    • Make sure to use the fuel line connected to the fuel filter for the input line.
    • Use caution when pulling on the gripping tool, if you use too much force you can not only puncture the fuel line, but you can also puncture the tank.
  11. Ryobi String Trimmer RY253SS Fuel Lines and Filter Replacement: step 11, image 1 of 3 Ryobi String Trimmer RY253SS Fuel Lines and Filter Replacement: step 11, image 2 of 3 Ryobi String Trimmer RY253SS Fuel Lines and Filter Replacement: step 11, image 3 of 3
    • Using the same methods as the previous steps, thread the output fuel line through the tank.
  12. Ryobi String Trimmer RY253SS Fuel Lines and Filter Replacement: step 12, image 1 of 3 Ryobi String Trimmer RY253SS Fuel Lines and Filter Replacement: step 12, image 2 of 3 Ryobi String Trimmer RY253SS Fuel Lines and Filter Replacement: step 12, image 3 of 3
    • Push the remaining fuel line into the gas tank.
  13. Ryobi String Trimmer RY253SS Fuel Lines and Filter Replacement: step 13, image 1 of 3 Ryobi String Trimmer RY253SS Fuel Lines and Filter Replacement: step 13, image 2 of 3 Ryobi String Trimmer RY253SS Fuel Lines and Filter Replacement: step 13, image 3 of 3
    • Use your cutting pliers to cut the excess fuel line to an appropriate length.
    • Cut the line to an appropriate length as shown in Picture 3.
  14. Ryobi String Trimmer RY253SS Fuel Lines and Filter Replacement: step 14, image 1 of 3 Ryobi String Trimmer RY253SS Fuel Lines and Filter Replacement: step 14, image 2 of 3 Ryobi String Trimmer RY253SS Fuel Lines and Filter Replacement: step 14, image 3 of 3
    • Attach the output fuel line back to the carburetor.
    • Attach the input fuel line back to the carburetor.
    • Push the fuel lines up as far as you can to the carburetor block.
To reassemble your device, follow steps 1 and 2 in reverse order.
3 other people completed this guide.
0 Comments
Past 24 Hours: 5
Past 7 Days: 55
Past 30 Days: 295
All Time: 6,614
