Ryobi VC120 Motor Replacement
  1. Ryobi VC120 Motor Replacement, Filter: step 1, image 1 of 1
    • Pull the black nose off of the body of the vacuum, by pushing in the orange button closest to the nose.
  2. Ryobi VC120 Motor Replacement: step 2, image 1 of 2 Ryobi VC120 Motor Replacement: step 2, image 2 of 2
    • Grab the filter with two fingers and slide it out.
  3. Ryobi VC120 Motor Replacement, Motor: step 3, image 1 of 2 Ryobi VC120 Motor Replacement, Motor: step 3, image 2 of 2
    • Using a Philips head screwdriver, remove the four screws located on the side panel of the vacuum.
    • There are two types of screws on this device. You may want to use a magnetic screw pad to organize your screws to be sure they return to their designated holes.
    • 4x 19.1mm
    • 1x 14.3mm
    • Once the screws are removed, you should be able to separate the side panel from the rest of the device.
  4. Ryobi VC120 Motor Replacement: step 4, image 1 of 3 Ryobi VC120 Motor Replacement: step 4, image 2 of 3 Ryobi VC120 Motor Replacement: step 4, image 3 of 3
    • Pull your motor out, and remove the black and red cables from the motor by hand.
3 other people completed this guide.
Allison Schoch
689 Reputation
4 Guides authored
IUPUI, Team 2-4, Baechle Fall 2015 Member of IUPUI, Team 2-4, Baechle Fall 2015
IUPUI-BAECHLE-F15S2G4
3 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 21
All Time: 1,064
