SG 552-1 Commando Barrel Replacement
  1. SG 552-1 Commando Barrel Replacement, Barrel: step 1, image 1 of 2 SG 552-1 Commando Barrel Replacement, Barrel: step 1, image 2 of 2
    • Using a flathead screwdriver, remove the pin holding the hand guard in place.
    • To remove this, turn the pin clockwise and push it through at the same time.
    • Pull the hand guard off.
  2. SG 552-1 Commando Barrel Replacement: step 2, image 1 of 2 SG 552-1 Commando Barrel Replacement: step 2, image 2 of 2
    • Using a Phillips #1 screwdriver, remove the two 8mm screws above the hand guard on both sides of the gun. There should be four total.
  3. SG 552-1 Commando Barrel Replacement: step 3, image 1 of 2 SG 552-1 Commando Barrel Replacement: step 3, image 2 of 2
    • Locate the button to fold over the folding stock and fold over the folding stock.
    • Using a Phillips #1 screwdriver, remove the 20mm screw located behind the folding stock.
  4. SG 552-1 Commando Barrel Replacement: step 4, image 1 of 2 SG 552-1 Commando Barrel Replacement: step 4, image 2 of 2
    • Turn the gun over so that you are facing the bottom of the gun.
    • Using a Phillips #1 screwdriver, remove the following screws:
    • Remove the 8mm screw located directly underneath the cocking lever.
    • Remove the 8mm screw beside the one you just removed.
  5. SG 552-1 Commando Barrel Replacement: step 5, image 1 of 2 SG 552-1 Commando Barrel Replacement: step 5, image 2 of 2
    • Carefully tug on the tip of the gun and pull the barrel and its cover out.
  6. SG 552-1 Commando Barrel Replacement: step 6, image 1 of 3 SG 552-1 Commando Barrel Replacement: step 6, image 2 of 3 SG 552-1 Commando Barrel Replacement: step 6, image 3 of 3
    • Pull the barrel out from the cover.
    • Remove the pieces at the end of the barrel.
  7. SG 552-1 Commando Barrel Replacement: step 7, image 1 of 2 SG 552-1 Commando Barrel Replacement: step 7, image 2 of 2
    • Remove the remaining pieces of on the ends of the barrel.
Laura Schulz
1 Reputation
1 Guide authored
Cal Poly, Team 18-41, Regan Fall 2012 Member of Cal Poly, Team 18-41, Regan Fall 2012
CPSU-REGAN-F12S18G41
6 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 1,673
