SG 552-1 Commando Motor Replacement
  1. SG 552-1 Commando Motor Replacement, Motor: step 1, image 1 of 2 SG 552-1 Commando Motor Replacement, Motor: step 1, image 2 of 2
    • Using a Phillips #0 screwdriver, remove the two 6mm screws located at the bottom of the hand grip.
    • Slide the cover off.
  2. SG 552-1 Commando Motor Replacement: step 2, image 1 of 1
    • Pull the motor out from the inside of the hand grip.
    • Using a soldering iron and desoldering wick, desolder the wires from the motor.
  3. SG 552-1 Commando Motor Replacement: step 3, image 1 of 1
    • Using a soldering iron, solder the wires onto the new motor.
Anika Morris
1 Reputation
4 Guides authored
Cal Poly, Team 18-41, Regan Fall 2012 Member of Cal Poly, Team 18-41, Regan Fall 2012
CPSU-REGAN-F12S18G41
6 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 777
