SG 552-1 Commando Spring Replacement
  1. SG 552-1 Commando Spring Replacement, Gearbox: step 1, image 1 of 2 SG 552-1 Commando Spring Replacement, Gearbox: step 1, image 2 of 2
    • Using a flathead screwdriver, remove the pin holding the hand guard in place.
    • To remove this, turn the pin clockwise and push it through at the same time.
    • Remove the hand guard.
  2. SG 552-1 Commando Spring Replacement: step 2, image 1 of 2 SG 552-1 Commando Spring Replacement: step 2, image 2 of 2
    • Using a Phillips #1 screwdriver, remove the two 8mm screws above the hand guard on both sides of the gun.
    • There should be four total.
  3. SG 552-1 Commando Spring Replacement: step 3, image 1 of 2 SG 552-1 Commando Spring Replacement: step 3, image 2 of 2
    • Turn the gun over so that you are facing the bottom of the gun.
    • Using a Phillips #1 screwdriver, remove the following screws:
    • Remove the 8mm screw that is located directly underneath the cocking lever.
    • Remove the 8mm screw located beside the screw you just removed.
  4. SG 552-1 Commando Spring Replacement: step 4, image 1 of 2 SG 552-1 Commando Spring Replacement: step 4, image 2 of 2
    • Carefully tug on the tip of the gun and pull the barrel and its cover out.
  5. SG 552-1 Commando Spring Replacement: step 5, image 1 of 3 SG 552-1 Commando Spring Replacement: step 5, image 2 of 3 SG 552-1 Commando Spring Replacement: step 5, image 3 of 3
    • Locate the hand grip.
    • Using a Phillips #0 screwdriver, remove the two 6mm screws at the bottom of the hand grip.
    • Slide the cover off.
  6. SG 552-1 Commando Spring Replacement: step 6, image 1 of 2 SG 552-1 Commando Spring Replacement: step 6, image 2 of 2
    • Pull the motor out of the hand grip.
    • Using a Phillips #1 screwdriver, remove the two 5mm screws inside of the hand grip.
  7. SG 552-1 Commando Spring Replacement: step 7, image 1 of 2 SG 552-1 Commando Spring Replacement: step 7, image 2 of 2
    • Locate the pin holding the folding stock in place.
    • Using an allen wrench or something small, carefully push the pin out.
  8. SG 552-1 Commando Spring Replacement: step 8, image 1 of 2 SG 552-1 Commando Spring Replacement: step 8, image 2 of 2
    • Using a Phillips #1 screwdriver, remove the 20mm screw behind the folding stock and above the gearbox.
    • Remove the cover that was held on by the screw.
  9. SG 552-1 Commando Spring Replacement: step 9, image 1 of 3 SG 552-1 Commando Spring Replacement: step 9, image 2 of 3 SG 552-1 Commando Spring Replacement: step 9, image 3 of 3
    • Using a flathead screwdriver, remove the two 5mm screws beside the safety switch on both sides of the gun.
    • Slide off the piece that was held on by those screws.
  10. SG 552-1 Commando Spring Replacement: step 10, image 1 of 2 SG 552-1 Commando Spring Replacement: step 10, image 2 of 2
    • Using a small allen wrench, carefully unscrew the screws holding the safety switch in place on both sides of the gun.
    • The screws do not have to be taken out all the way, just slightly loosen them until you are able to pull the switch off.
  11. SG 552-1 Commando Spring Replacement: step 11, image 1 of 2 SG 552-1 Commando Spring Replacement: step 11, image 2 of 2
    • Using a Phillips #0 screwdriver, remove the two 6mm screws that were underneath the safety switch on both sides of the gun.
    • Carefully remove the pieces that were held on by the screws.
  12. SG 552-1 Commando Spring Replacement: step 12, image 1 of 3 SG 552-1 Commando Spring Replacement: step 12, image 2 of 3 SG 552-1 Commando Spring Replacement: step 12, image 3 of 3
    • Pull apart the cover when pulling the gearbox out.
    • Pull the gearbox out.
    • The gears will fall out when taking the gearbox out. Careful not to lose them.
  13. SG 552-1 Commando Spring Replacement, Spring: step 13, image 1 of 2 SG 552-1 Commando Spring Replacement, Spring: step 13, image 2 of 2
    • Remove these four 15mm screws.
    • Remove this single 8mm screw.
    • Using a Phillips #0 screwdriver, remove the following screws:
    • Remove this single 3mm screw.
    • Remove this single 14mm screw.
    • Detach the pieces unscrewed from the gearbox.
  14. SG 552-1 Commando Spring Replacement: step 14, image 1 of 2 SG 552-1 Commando Spring Replacement: step 14, image 2 of 2
    • Remove the piece covering the trigger.
    • Remove the safety piece.
    • Using a Phillips #1 screwdriver, remove the 18mm screw beside the trigger.
  15. SG 552-1 Commando Spring Replacement: step 15, image 1 of 1
    • Remove the metal piece.
    • Removing this piece will permanently damage the metal piece.
  16. SG 552-1 Commando Spring Replacement: step 16, image 1 of 3 SG 552-1 Commando Spring Replacement: step 16, image 2 of 3 SG 552-1 Commando Spring Replacement: step 16, image 3 of 3
    • Remove the cover and pull out the spring.
Anika Morris
1 Reputation
4 Guides authored
Cal Poly, Team 18-41, Regan Fall 2012 Member of Cal Poly, Team 18-41, Regan Fall 2012
CPSU-REGAN-F12S18G41
6 Members
6 Guides authored
One Comment
When i read step 15 it seems impossible to up/downgrade spring without damaging the gun permanently??
Marco den Hartog - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 1,863
