SHARK WANDVAC WV205 Battery Replacement
  1. SHARK WANDVAC WV205 Battery Replacement, Battery: step 1, image 1 of 2 SHARK WANDVAC WV205 Battery Replacement, Battery: step 1, image 2 of 2
    • Push the sliding button to open the dirt capsule to empty it out.
    • Ensure to do this over a garbage can/bag to prevent a mess.
  2. SHARK WANDVAC WV205 Battery Replacement: step 2, image 1 of 2 SHARK WANDVAC WV205 Battery Replacement: step 2, image 2 of 2
    • Using a coin or other thin item, such as a guitar pick, push the cap at the end of the vacuum out. Switch between sides to make it come out evenly.
    • This could take more time than expected.
  3. SHARK WANDVAC WV205 Battery Replacement: step 3, image 1 of 2 SHARK WANDVAC WV205 Battery Replacement: step 3, image 2 of 2
    • Once the battery is popped out, carefully pull it out.
  4. SHARK WANDVAC WV205 Battery Replacement: step 4, image 1 of 2 SHARK WANDVAC WV205 Battery Replacement: step 4, image 2 of 2
    • To properly store and then dispose of the battery put it in a clear plastic bag.
  5. SHARK WANDVAC WV205 Battery Replacement: step 5, image 1 of 2 SHARK WANDVAC WV205 Battery Replacement: step 5, image 2 of 2
    • Slot your replacement battery where the old one was.
    • Once inside, push hard on the end until you hear a click.
  6. SHARK WANDVAC WV205 Battery Replacement: step 6, image 1 of 1
    • Test the vacuum to ensure the replacement succeeded.
To properly dispose of the old battery consult your cities policies on lithium ion battery disposal.
Nicolaas
133 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 62
All Time: 178
