SHARP EL-546XT Battery Replacement
  1. SHARP EL-546XT Battery Replacement, Battery: step 1, image 1 of 2 SHARP EL-546XT Battery Replacement, Battery: step 1, image 2 of 2
    • Place the calculator on a clean workspace with the back facing up.
  2. SHARP EL-546XT Battery Replacement: step 2, image 1 of 3 SHARP EL-546XT Battery Replacement: step 2, image 2 of 3 SHARP EL-546XT Battery Replacement: step 2, image 3 of 3
    • Remove the calculator cover if you had it on.
    • Turn off the calculator using the 2nd F button then clicking the ON button.
  3. SHARP EL-546XT Battery Replacement: step 3, image 1 of 3 SHARP EL-546XT Battery Replacement: step 3, image 2 of 3 SHARP EL-546XT Battery Replacement: step 3, image 3 of 3
    • Put the calculator cover back on to ensure you don't accidentally press any buttons.
    • Remove the screws from the battery door.
    • Do not remove the other screws as they are not for the battery compartment.
  4. SHARP EL-546XT Battery Replacement: step 4, image 1 of 2 SHARP EL-546XT Battery Replacement: step 4, image 2 of 2
    • Remove the battery door from the calculator.
  5. SHARP EL-546XT Battery Replacement: step 5, image 1 of 3 SHARP EL-546XT Battery Replacement: step 5, image 2 of 3 SHARP EL-546XT Battery Replacement: step 5, image 3 of 3
    • Use a spudger to gently push the coin battery out through the small hole located below the battery.
    • Be careful not to apply too much force when pushing the old battery out to avoid damaging the calculator or the battery compartment.
  6. SHARP EL-546XT Battery Replacement: step 6, image 1 of 3 SHARP EL-546XT Battery Replacement: step 6, image 2 of 3 SHARP EL-546XT Battery Replacement: step 6, image 3 of 3
    • Gently insert the new battery into the battery compartment.
    • Handle the new batteries with care.
  7. SHARP EL-546XT Battery Replacement: step 7, image 1 of 2 SHARP EL-546XT Battery Replacement: step 7, image 2 of 2
    • Ensure the battery is properly slotted in the battery compartment.
    • Close the battery compartment with the battery door.
  8. SHARP EL-546XT Battery Replacement: step 8, image 1 of 3 SHARP EL-546XT Battery Replacement: step 8, image 2 of 3 SHARP EL-546XT Battery Replacement: step 8, image 3 of 3
    • Attach the screws back to the battery door.
  9. SHARP EL-546XT Battery Replacement: step 9, image 1 of 3 SHARP EL-546XT Battery Replacement: step 9, image 2 of 3 SHARP EL-546XT Battery Replacement: step 9, image 3 of 3
    • Take the calculator out of the cover.
    • Turn on the calculator and test if it's functioning.
Finish Line
Mithunan Sivagnanam
169 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 26
All Time: 522
