SOMNOcomfort and SOMNObalance Ventilator Filter Replacement
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
  1. SOMNOcomfort and SOMNObalance Ventilator Filter Replacement, Filter: step 1, image 1 of 1
    • Locate the Filter Compartment on the back of the ventilator.
  2. SOMNOcomfort and SOMNObalance Ventilator Filter Replacement: step 2, image 1 of 1
    • Push the compartment cover (22) up (from the bottom)
  3. SOMNOcomfort and SOMNObalance Ventilator Filter Replacement: step 3, image 1 of 1
    • Remove the coarse dust filter(68)
  4. SOMNOcomfort and SOMNObalance Ventilator Filter Replacement: step 4, image 1 of 1
    • Remove the fine dust filter(67)
    • Replace the filters and close the cover on the rear of the unit.
  5. SOMNOcomfort and SOMNObalance Ventilator Filter Replacement: step 6, image 1 of 1
    • Reset the filter change indicator by pressing and holding the on/off switch(19) until the filter change indicator goes blank.
    • If the fine filter was changed due to soiling before 250 operating hours, the hours meter must be reset to zero. Proceed as follows:
    • When switching the unit on, press and hold the on/off switch 19. The filter change indicator will come on after about three seconds before going off again after another three seconds. Release the on and off switch.
Diya Jamwal
553 Reputation
3 Guides authored
Cal Poly, Team S1-G3, Zimmerman Spring 2020 Member of Cal Poly, Team S1-G3, Zimmerman Spring 2020
CPSU-ZIMMERMAN-S20S1G3
5 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 9
All Time: 136
