SONY Ericsson W890i Keypad and Front Cover Replacement
  1. SONY Ericsson W890i Keypad and Front Cover Replacement, Battery: step 1, image 1 of 1
    • Flick the two lock tabs into the unlocked positions by pushing each button forward.
  2. SONY Ericsson W890i Keypad and Front Cover Replacement: step 2, image 1 of 1
    • Pop the back cover up using the groove on the top of the phone.
  3. SONY Ericsson W890i Keypad and Front Cover Replacement: step 3, image 1 of 1
    • You can now access the phone's battery.
    • Using a spudger, remove the battery and set it aside.
  4. SONY Ericsson W890i Keypad and Front Cover Replacement, Keypad and Front Cover: step 4, image 1 of 2 SONY Ericsson W890i Keypad and Front Cover Replacement, Keypad and Front Cover: step 4, image 2 of 2
    • Remove the two small rubber pieces that cover the lower screws.
    • Using a T-6 Torx wrench or screwdriver, remove all four of the small screws at the top and bottom corners on the back of the phones.
  5. SONY Ericsson W890i Keypad and Front Cover Replacement: step 5, image 1 of 1
    • Gently pry off the faceplate using a plastic opening tool.
    • Insert the plastic opening tool into the middle of the front and back panels of the phone.
  6. SONY Ericsson W890i Keypad and Front Cover Replacement: step 6, image 1 of 1
    • Separate the front and back panels that were pryed open with the plastic opening tool.
Bob
316 Reputation
3 Guides authored
SUNY Cortland, Team 1-3, Getto Spring 2013 Member of SUNY Cortland, Team 1-3, Getto Spring 2013
SUNYCORT-GETTO-S13S1G3
3 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 1,001
