SONY ZS-BTG900 Disassembly
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. SONY ZS-BTG900 Disassembly, SONY ZS-BTG900 Disassembly: step 1, image 1 of 2 SONY ZS-BTG900 Disassembly, SONY ZS-BTG900 Disassembly: step 1, image 2 of 2
    • Lift up the handle to reveal the screws.
    • Use your Phillips #2 screwdriver to remove the eight 1/2 inch screws.
  2. SONY ZS-BTG900 Disassembly: step 2, image 1 of 3 SONY ZS-BTG900 Disassembly: step 2, image 2 of 3 SONY ZS-BTG900 Disassembly: step 2, image 3 of 3
    • Flip your device over.
    • Use your Phillips #2 screwdriver to remove the six 3/4inch screws.
    • In removing the screws within the two holes on the back of the device, you may want to use your shaft extension to provide extra torque as they may be very tight.
  3. SONY ZS-BTG900 Disassembly: step 3, image 1 of 2 SONY ZS-BTG900 Disassembly: step 3, image 2 of 2
    • Flip your device back over to access the top of the device.
    • Use your plastic opening tool to pry up and remove the panel on the top, left hand side of the device.
    • This will reveal two additional screws.
  4. SONY ZS-BTG900 Disassembly: step 4, image 1 of 1
    • Use your Phillips #2 screwdriver to remove the two 1/2 inch screws underneath the now-removed panels.
  5. SONY ZS-BTG900 Disassembly: step 5, image 1 of 2 SONY ZS-BTG900 Disassembly: step 5, image 2 of 2
    • Lift off the top, beginning from the back of the device.
    • Take care when lifting the top portion as there are many wires connected to the inside of the device and you do not want to disconnect these just yet.
  6. SONY ZS-BTG900 Disassembly: step 6, image 1 of 2 SONY ZS-BTG900 Disassembly: step 6, image 2 of 2
    • Disconnect the CD drive ribbon cable from the top of the device.
  7. SONY ZS-BTG900 Disassembly: step 7, image 1 of 2 SONY ZS-BTG900 Disassembly: step 7, image 2 of 2
    • Disconnect the antenna cables.
  8. SONY ZS-BTG900 Disassembly: step 8, image 1 of 3 SONY ZS-BTG900 Disassembly: step 8, image 2 of 3 SONY ZS-BTG900 Disassembly: step 8, image 3 of 3
    • Disconnect the remaining cables from the motherboard.
  9. SONY ZS-BTG900 Disassembly: step 9, image 1 of 2 SONY ZS-BTG900 Disassembly: step 9, image 2 of 2
    • Once you have removed the top, we will begin removing the front of the device.
    • Begin by disconnecting the 6 cables that lead from the front of the device to the motherboard.
  10. SONY ZS-BTG900 Disassembly: step 10, image 1 of 1
    • Use your Philips #2 screwdriver to remove the two 1 inch screws on the outermost part of the device.
    • Use your Philips #2 screwdriver to remove the two 3/4 inch screws on the outermost part of the device.
    • Use your Philips #2 screwdriver to remove the one 5/6 inch screw on the middle part of the device.
  11. SONY ZS-BTG900 Disassembly: step 11, image 1 of 2 SONY ZS-BTG900 Disassembly: step 11, image 2 of 2
    • Firmly pull off the front of device.
    • There will be a small amount of black glue. You can simply ignore this, and continue to pull, or use a sharp edge to cut the glue once you've revealed it.
Alfredo Rodriguez
972 Reputation
8 Guides authored
One Comment
Alfredo and any others who developed this guide - you are awesome! Thank you very much for the great level of detail. Saved me a bunch of time.
Mike L - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 667
