SR405QM Battery Replacement
  1. SR405QM Battery Replacement, Battery: step 1, image 1 of 1
    • Gently place the instrument upside-down on a soft surface.
    • Locate the battery cavity cap and screws.
  2. SR405QM Battery Replacement: step 2, image 1 of 1
    • Use a Phillips #2 head screwdriver to unscrew both screws. Two #1 1mm long screws.
  3. SR405QM Battery Replacement: step 3, image 1 of 2 SR405QM Battery Replacement: step 3, image 2 of 2
    • Remove the cap by lifting upwards to reveal the battery.
  4. SR405QM Battery Replacement: step 4, image 1 of 3 SR405QM Battery Replacement: step 4, image 2 of 3 SR405QM Battery Replacement: step 4, image 3 of 3
    • Gently lift the battery from the cavity.
    • Detach the battery completely by firmly pulling the fabric connector from the conducting end of the battery.
To reassemble your device, follow these instructions in reverse order with a fresh battery.
2 other people completed this guide.
Chris Pittner
220 Reputation
7 Guides authored
Cal Poly, Team 5-18, Forte Winter 2013 Member of Cal Poly, Team 5-18, Forte Winter 2013
CPSU-FORTE-W13S5G18
4 Members
9 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 1,180
