SSD Replacement
  1. SSD Replacement, removal of bottom case: step 1, image 1 of 2 SSD Replacement, removal of bottom case: step 1, image 2 of 2
    • remove the feet with a spudger
  2. SSD Replacement: step 2, image 1 of 2 SSD Replacement: step 2, image 2 of 2
    • Remove the 11 screw with a PH0 screwdriver.
    • The screws are identical
  3. SSD Replacement: step 3, image 1 of 2 SSD Replacement: step 3, image 2 of 2
    • Insert a spudger between the bottom cover and the keyboard module, then go around the whole cover to uncip everything.
    • Remove the bottom cover from the computer.
  4. SSD Replacement: step 4, image 1 of 1
    • You now have acces to the inside of the machine.
  5. SSD Replacement, SSD: step 5, image 1 of 1
    • remove the screw with your PH0 screwdriver
  6. SSD Replacement: step 6, image 1 of 2 SSD Replacement: step 6, image 2 of 2
    • slide the SSD out of the m.2 slot
    • It may be necessary to slightly lift up the back of the SSD
    • The SSD is now removed
Install your SSD
To reassemble your machine, follow the instructions in reverse order.
Special thanks to these translators:
fr en
100%
S Devaud is helping us fix the world! Want to contribute?
Start translating ›
Léo FRAYSSE
1,379 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 14
All Time: 582
