Saeco Minuto outer case
  1. Saeco Minuto outer case, opening procedure: step 1, image 1 of 1
    • Disconnect the power plug!
    • Remove the water tank.
    • Remove all the coffee beans.
    • Remove the brewing assembly.
    • Remove the drip tray and the coffee grounds drawer.
  2. Saeco Minuto outer case: step 2, image 1 of 3 Saeco Minuto outer case: step 2, image 2 of 3 Saeco Minuto outer case: step 2, image 3 of 3
    • Pry up with a plastic opening tool at the bottom edge of the chrome-plated cover to lift up the coffee dispensing spout. This cover is often very tight, so you have to pry hard and hope that the part does not break.
    • When the lower edge of the spout is released, you can pry on the side edge until the chrome cover comes off completely.
  3. Saeco Minuto outer case: step 3, image 1 of 2 Saeco Minuto outer case: step 3, image 2 of 2
    • Remove the Torx T10 screw at the top edge of the coffee dispensing spout.
  4. Saeco Minuto outer case: step 4, image 1 of 2 Saeco Minuto outer case: step 4, image 2 of 2
    • Lift off the black cover over the coffee dispensing spout. The sliding nozzles will come off at the same time.
  5. Saeco Minuto outer case: step 5, image 1 of 1
    • Remove both Torx T10 screws on the left and right at the bottom edge of the coffee dispensing spout.
    • Pull off the hot water dispensing spout.
  6. Saeco Minuto outer case: step 6, image 1 of 2 Saeco Minuto outer case: step 6, image 2 of 2
    • Remove the Torx T20 screw on the finger guard of the grinder. Remove the finger guard.
    • If the screws are covered with coffee remains, you should first clean them with a needle and a vacuum cleaner.
    • Remove three Torx T10 screws in the bean container.
  7. Saeco Minuto outer case: step 7, image 1 of 1
    • Remove the three Torx T10 screws under the water tank.
  8. Saeco Minuto outer case: step 8, image 1 of 3 Saeco Minuto outer case: step 8, image 2 of 3 Saeco Minuto outer case: step 8, image 3 of 3
    • Grab the upper cover on the sides and lift it up.
    • The cover is still connected with a cable and a tube.
    • Take off the silicone tube.
  9. Saeco Minuto outer case: step 9, image 1 of 1
    • Remove the water level sensor cable from its brackets.
    • Carefully remove the plug from the water level sensor.
    • The cover is now free and can be removed.
  10. Saeco Minuto outer case, remove outer casing: step 10, image 1 of 3 Saeco Minuto outer case, remove outer casing: step 10, image 2 of 3 Saeco Minuto outer case, remove outer casing: step 10, image 3 of 3
    • Open the service Dior.
    • Remove five Torx T10 screws.
  11. Saeco Minuto outer case: step 11, image 1 of 1
    • Remove one T10 Torx screw securing the top of the grinder.
  12. Saeco Minuto outer case: step 12, image 1 of 2 Saeco Minuto outer case: step 12, image 2 of 2
    • If you haven't already done so: Unscrew the center Torx T10 screw at the bottom of the coffee spout distributor.
    • Unscrew the Torx T10 screw in the middle left front.
    • Lift the service door up and remove it.
  13. Saeco Minuto outer case: step 13, image 1 of 2 Saeco Minuto outer case: step 13, image 2 of 2
    • Unscrew the Torx T10 screw securing the coffee spout distributor inside.
  14. Saeco Minuto outer case: step 14, image 1 of 1
    • Lift the coffee spout distributor up and remove it.
    • The coffee spout distributor tends to be dirty. Open it and clean it thorougly.
  15. Saeco Minuto outer case: step 15, image 1 of 1
    • You should now be able to lift the inner frame out of the outer one. On some models, it is still attached with other screws.
    • Lift the inner frame up and remove it from the outer case. It may get stuck a bit, help with a plastic lever tool.
  16. Saeco Minuto outer case: step 16, image 1 of 3 Saeco Minuto outer case: step 16, image 2 of 3 Saeco Minuto outer case: step 16, image 3 of 3
    • This is what the inner frame looks like from three sides. All components are easily accessible, especially the pump, the flowmeter and the heater.
  17. Saeco Minuto outer case: step 17, image 1 of 1
    • And this is what the completely gutted outer case looks like. It can now be cleaned well.
Repeat the steps in reverse order to reassemble your device.
6 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
VauWeh
300,429 Reputation
303 Guides authored
1 Guide Comment
For the Saeco Pico Barista, it is pretty much the same…
This manual was a big help to fix the unit (t° sensor on boiler had to be replaced).
Thx !
Kurt Van Collie - Reply
Past 24 Hours: 5
Past 7 Days: 33
Past 30 Days: 167
All Time: 7,586
