Saeco Vienna Sup 018 steam valve replacement
  1. Saeco Vienna Sup 018 steam valve replacement, Removing Saeco Vienna Sup 018 Top Cover: step 1, image 1 of 1
    • Never forget: Pull the plug out!
    • Remove all attachments such as drawers, water tank, brewing unit.
    • Carefully pull the steam button out. If it is too tight, first loosen the cover (steps 2 to 4), lift slightly and then push the ratchet nose with a small screwdriver.
  2. Saeco Vienna Sup 018 steam valve replacement: step 2, image 1 of 1
    • The bean container is fixed with two Phillipps screws. Unscrew those.
    • The adjusters of the grinder and the quantity of coffee (if present) can remain.
    • Lift the bean container up und remove it from the device.
  3. Saeco Vienna Sup 018 steam valve replacement: step 3, image 1 of 3 Saeco Vienna Sup 018 steam valve replacement: step 3, image 2 of 3 Saeco Vienna Sup 018 steam valve replacement: step 3, image 3 of 3
    • Remove the single T10 Torx screw on the rear edge of the top cover under the water reservoir.
    • Remove the single Phillipps screw on the rear edge of the top cover under the container of the coffee beans.
    • There are two Phillipps screws on the frontal unterside edge of the top cover. Turn them out.
  4. Saeco Vienna Sup 018 steam valve replacement: step 4, image 1 of 1
    • Now the cover can be lifted off. Pull backwards, then diagonally forward. Remove the silicone hose from the water tank.
  5. Saeco Vienna Sup 018 steam valve replacement, Steam Valve: step 5, image 1 of 1
    • The steam valve is located on the top right of the machine. If it has cracks, water will drip out of the valve body.
  6. Saeco Vienna Sup 018 steam valve replacement: step 6, image 1 of 1
    • Remove the clamp securing the pressure hose to the valve body.
    • Disconnect the pressure hose from the valve body.
    • The end of the pressure hose is sealed with two O-rings. Those will either stick on the valve body or on the pressure hose. Whenever possible replace them when re-assembling.
  7. Saeco Vienna Sup 018 steam valve replacement: step 7, image 1 of 1
    • The steam valve must be pushed to the right, but a microswitch will still be in the way.
    • The microswitch is mounted on the underside of the gray frame with two notches. Insert a small screwdriver into the gap under the gray frame. Gently push the two notches one after the other and lift the microswitch upwards. The cables can stay connected.
  8. Saeco Vienna Sup 018 steam valve replacement: step 8, image 1 of 1
    • The steam valve is still secured with a catch. Lift the catch with a flat-head screwdriver and slide the complete valve to the right.
    • To remove the valve it can now be pulled out of the gray frame in a forward direction.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
VauWeh
210,422 Reputation
255 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
27 Members
1,186 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 16
All Time: 2,235
