Saeco Vienna Sup 018 support valve descaling
  1. Saeco Vienna Sup 018 support valve descaling, Prepare descaling liquid: step 1, image 1 of 1
    • Prepare descaling liquid (see comments) and fill it into the water tank (as with the usual descaling according to the instructions)
  2. Saeco Vienna Sup 018 support valve descaling, Enter test mode: step 2, image 1 of 1
    • Switch off the coffee machine
    • Press and hold the coffee and steam buttons while switching the machine on -> The test mode is activated
    • The test mode is not indicated by any LEDs. I found the information about the test mode on www.m-landmann.eu, among other things
  3. Saeco Vienna Sup 018 support valve descaling, Move the brewing group to the brewing position: step 3, image 1 of 3 Saeco Vienna Sup 018 support valve descaling, Move the brewing group to the brewing position: step 3, image 2 of 3 Saeco Vienna Sup 018 support valve descaling, Move the brewing group to the brewing position: step 3, image 3 of 3
    • Set volume control (green) to minimum (all the way to the left)
    • Press and hold the steam button until the LED next to the coffee cup lights up (yellow mark)
    • The brew group is now in the brewing position and the support valve (pink) is activated.
  4. Saeco Vienna Sup 018 support valve descaling, Descale: step 4, image 1 of 1
    • The quantity regulation remains at minimum.
    • Place a (large) empty cup under the spout
    • Press and hold the coffee button until the pump dispenses approximately one cup of liquid. For information: The error display flashes approx. 600 times for 200ml of water.
    • wait about 20 minutes ( to take full effect)
    • Pump out the rest of the descaling liquid in cups, pausing the pumping with 3-minute breaks.
  5. Saeco Vienna Sup 018 support valve descaling, Rinse the brew group: step 5, image 1 of 1
    • Rinse out the water tank and fill it up with clear water
    • Pour off a few cups of water as in the last step, rinsing out the remains of the citric acid.
  6. Saeco Vienna Sup 018 support valve descaling, Place the brewing group into sleep mode: step 6, image 1 of 1
    • Set the volume control to the middle and hold down the steam button until the LED next to the coffee button lights up. The brew group is now back in its original position.
    • Switch off the machine and switch it on again as usual - Descaling complete.
Finish Line
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
Peter Scholl
1,440 Reputation
6 Guides authored
AEG-Make&Repair AG Member of AEG-Make&Repair AG
Local Repair Groups
3 Members
12 Guides authored
0 Comments
Past 24 Hours: 5
Past 7 Days: 32
Past 30 Days: 118
All Time: 3,992
