Safety Precautions
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Safety Precautions, Disconnect the spark plug wire: step 1, image 1 of 2 Safety Precautions, Disconnect the spark plug wire: step 1, image 2 of 2
    • Before you begin, ensure that the engine is powered down and cool to the touch.
    • Grab the plastic housing at the end of the spark plug wire and pull firmly to disconnect it.
  2. Safety Precautions, Flip the engine switch to the off position: step 2, image 1 of 2 Safety Precautions, Flip the engine switch to the off position: step 2, image 2 of 2
    • Flip the red engine ON/OFF switch to the OFF position.
  3. Safety Precautions, Close the fuel valve: step 3, image 1 of 2 Safety Precautions, Close the fuel valve: step 3, image 2 of 2
    • Flip the fuel valve lever to the OFF position.
  4. Safety Precautions, Turn off the ignition: step 4, image 1 of 2 Safety Precautions, Turn off the ignition: step 4, image 2 of 2
    • Flip the ignition switch to the OFF position.
    • Ensure the wheel drive control lever is set to the neutral position.
  5. Safety Precautions, Allow the wheels to freewheel: step 5, image 1 of 3 Safety Precautions, Allow the wheels to freewheel: step 5, image 2 of 3 Safety Precautions, Allow the wheels to freewheel: step 5, image 3 of 3
    • Pull the locking pin out and rotate it 90˚ to unlock the right wheel from the hub.
    • Repeat for the left wheel.
  6. Safety Precautions, Add wheel chocks: step 6, image 1 of 1
    • Insert wheel chocks underneath each wheel to keep the device stationary during disassembly.
Carsten Frauenheim
135,488 Reputation
371 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,410 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 7
