Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement
  1. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement, Battery: step 1, image 1 of 2 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement, Battery: step 1, image 2 of 2
    • Remove all external power and turn off the tablet.
    • Insert a plastic opening tool between the screen and rear casing.
    • Pry the screen and rear casing apart.
  2. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: step 2, image 1 of 3 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: step 2, image 2 of 3 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: step 2, image 3 of 3
    • Remove the three green pieces of tape covering the white, black, and gold ribbon cables.
    • Use a spudger to flip up the retaining flap on the three ribbon cable ZIF sockets.
    • Pull the ribbon cables out of the sockets.
  3. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: step 3, image 1 of 3 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: step 3, image 2 of 3 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: step 3, image 3 of 3
    • Remove the ten 4mm Phillips #000 screws from the battery.
    • Use a plastic opening tool to pry up the battery.
    • Remove the battery.
  4. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement, Home Button: step 4, image 1 of 2 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement, Home Button: step 4, image 2 of 2
    • Remove the green protective tape from the three ZIF connectors on the motherboard.
    • Pull the ribbon cables out of their sockets.
  5. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: step 5, image 1 of 2 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: step 5, image 2 of 2
    • Remove the six 4mm Phillips #000 screws from the motherboard.
    • Remove the motherboard.
  6. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: step 6, image 1 of 2 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: step 6, image 2 of 2
    • Insert a plastic opening tool between the screen and bezel.
    • Slide the plastic opening tool around the perimeter while applying a prying motion.
    • Remove the screen from the display.
    • Applying heat may be needed to loosed the glue.
  7. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: step 7, image 1 of 2 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: step 7, image 2 of 2
    • Locate the Home button on the front of the panel and carefully lift the gold ribbon surrounding it from RIGHT to LEFT.
  8. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: step 8, image 1 of 1
    • Using your Phillips #000 screwdriver Remove the two 4mm Phillips #000 screws from the home button.
  9. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: step 9, image 1 of 1
    • Remove the home button by sliding it to the left or right while pulling up.
Guneet Bawa
688 Reputation
4 Guides authored
UW Tacoma, Team S1-G5, Liner Spring 2018 Member of UW Tacoma, Team S1-G5, Liner Spring 2018
UWT-LINER-S18S1G5
5 Members
8 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 17
All Time: 2,003
