Samsung Galaxy Watch5 Battery Replacement
  1. Samsung Galaxy Watch5 Battery Replacement, Remove the watch band: step 1, image 1 of 1
    • Take your watch off the charger and power it down.
    • Remove the watch band.
  2. Samsung Galaxy Watch5 Battery Replacement, Unfasten the back cover: step 2, image 1 of 1
    • Use a Tri-point Y00 screwdriver to remove the four 4.1 mm-long screws securing the back cover.
  3. Samsung Galaxy Watch5 Battery Replacement, Pry the back cover: step 3, image 1 of 2 Samsung Galaxy Watch5 Battery Replacement, Pry the back cover: step 3, image 2 of 2
    • Insert an opening tool into the seam between the back cover and the metal housing.
    • Twist the opening tool to loosen the gasket and create a gap.
    • Don't try to remove the back cover all the way yet. The sensor flex cable is still connected to the motherboard.
  4. Samsung Galaxy Watch5 Battery Replacement, Disconnect the sensor flex cable: step 4, image 1 of 2 Samsung Galaxy Watch5 Battery Replacement, Disconnect the sensor flex cable: step 4, image 2 of 2
    • Lay the watch screen-side down.
    • Carefully swing open the back cover at the gap you just created.
    • Use a spudger to disconnect the sensor flex cable from the motherboard by prying the press connector straight up from its socket.
    • During reassembly, this is a good point to turn on your device and test your repair before resealing it.
  5. Samsung Galaxy Watch5 Battery Replacement, Remove the back cover: step 5, image 1 of 2 Samsung Galaxy Watch5 Battery Replacement, Remove the back cover: step 5, image 2 of 2
    • Remove the back cover.
    • During reassembly:
    • Make sure the rubber gasket (marked in red) is undamaged. If damaged, replace it with a new one to maintain water resistance.
  6. Samsung Galaxy Watch5 Battery Replacement, Disconnect the display flex cable: step 6, image 1 of 2 Samsung Galaxy Watch5 Battery Replacement, Disconnect the display flex cable: step 6, image 2 of 2
    • Use a spudger to disconnect the display flex cable by prying the connector straight up from its socket.
  7. Samsung Galaxy Watch5 Battery Replacement, Disconnect the button flex cable: step 7, image 1 of 2 Samsung Galaxy Watch5 Battery Replacement, Disconnect the button flex cable: step 7, image 2 of 2
    • Use a spudger to disconnect the button flex cable by prying the connector straight up from its socket.
  8. Samsung Galaxy Watch5 Battery Replacement, Unfasten the motherboard: step 8, image 1 of 1
    • Use a Phillips screwdriver to remove the single 4.4 mm–long screw securing the motherboard.
  9. Samsung Galaxy Watch5 Battery Replacement, Remove the motherboard: step 9, image 1 of 2 Samsung Galaxy Watch5 Battery Replacement, Remove the motherboard: step 9, image 2 of 2
    Tool used on this step:
    Buy
    • Use a pair of tweezers or your fingers to lift the motherboard out from the watch, clearing the two flex cables.
  10. Samsung Galaxy Watch5 Battery Replacement, Pry up the battery: step 10, image 1 of 2 Samsung Galaxy Watch5 Battery Replacement, Pry up the battery: step 10, image 2 of 2
    • Place a spudger into the small gap between the plastic frame and the battery, opposite the display cable.
    • Carefully pry the battery up and out of its recess.
    • The battery is adhered to the core with mild adhesive. If it feels stuck, lightly heat it with an iOpener or hair dryer to soften the adhesive underneath.
    • Don't try to fully remove the battery just yet, as its connector is still adhered to the core assembly.
  11. Samsung Galaxy Watch5 Battery Replacement, Release the battery connector: step 11, image 1 of 2 Samsung Galaxy Watch5 Battery Replacement, Release the battery connector: step 11, image 2 of 2
    Buy
    • Lift the battery up enough to access its glued-down connector cable.
    • Use a pair of tweezers to peel the battery connector from the frame.
    • You'll most likely be able to reuse the existing adhesive to secure the new battery. If it's not sticky enough, use double sided or pre-cut adhesive tape.
  12. Samsung Galaxy Watch5 Battery Replacement, Remove the battery: step 12, image 1 of 2 Samsung Galaxy Watch5 Battery Replacement, Remove the battery: step 12, image 2 of 2
    Tesa 61395 Tape
    $5.99
    Buy
    • Use a pair of tweezers or your fingers to remove the battery.
    • Don't accidentally poke or slice the battery with any sharp tools. A punctured battery may leak dangerous chemicals or catch fire.
    • Never reuse a deformed or damaged battery—it's a fire hazard. Replace it with a new battery.
    • To install a new battery:
    • Use tweezers or your fingers to remove the old adhesive from the frame.
    • Use high-concentration isopropyl alcohol (>90%) and a lint-free cloth to remove any remaining adhesive residue.
    • If your replacement battery isn‘t already equipped with adhesive, apply thin, double-sided tape such as Tesa Tape directly to the battery recess where the old adhesive was.
    • Lay the replacement battery in its recess and press down firmly to secure it.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
For optimal performance, calibrate your newly installed battery after completing this guide.
8 other people completed this guide.
Manuel Haeussermann
19,496 Reputation
71 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,529 Guides authored
11 Comments
Are there any recommended batteries to replace the OEM one with?
Caleb Angell - Reply
Hi Caleb Angell, while I can't give a specific recommendation, replacement batteries might be found using the part number: EB-BR910ABY (44 mm model) and EB-BR900ABY (40 mm model).
Manuel Haeussermann -
Is this good for the watch 5 pro too?
Antonella Carletti - Reply
Hi Antonella Carletti, I think it's reasonable to assume so from a quick look at the Watch5 Pro specs and look, but I haven't handled the Watch5 Pro myself and was unable to find disassembly resources, so you should take this as more of a guess.
Thanks for your response Manuel, I'll give it a go.
Past 24 Hours: 22
Past 7 Days: 177
Past 30 Days: 792
All Time: 14,767
