Samsung 27E510C NAV Button Replacement
  1. Samsung 27E510C  NAV Button Replacement, Back Panel: step 1, image 1 of 3 Samsung 27E510C  NAV Button Replacement, Back Panel: step 1, image 2 of 3 Samsung 27E510C  NAV Button Replacement, Back Panel: step 1, image 3 of 3
    • Use the #1 Phillips head screw driver to remove each 13.75mm length screw from the rear panel.
    • The screw alone with the ports is a different size than the rest, its length is 12mm.
  2. Samsung 27E510C  NAV Button Replacement: step 2, image 1 of 2 Samsung 27E510C  NAV Button Replacement: step 2, image 2 of 2
    Tool used on this step:
    Heavy-Duty Spudger
    Buy
    • Insert the heavy duty spudger in between the monitors back panel and its frame.
    • Use the heavy duty spudger to pry open the back panel.
    • Over aggressive prying could break the tabs holding the back panel in place.
  3. Samsung 27E510C  NAV Button Replacement, Rear navigation button: step 3, image 1 of 1
    • Carefully remove the tape holding down the connector wire.
    • You will need to re-attach the tape upon reassembly.
  4. Samsung 27E510C  NAV Button Replacement: step 4, image 1 of 1
    • Disconnect the navigation button from the motherboard by holding down the thumb tab and pulling its connector out.
  5. Samsung 27E510C  NAV Button Replacement: step 5, image 1 of 2 Samsung 27E510C  NAV Button Replacement: step 5, image 2 of 2
    • Remove the navigation buttons connector wire from the monitors body tab.
  6. Samsung 27E510C  NAV Button Replacement: step 6, image 1 of 1
    • With one thumb, hold down the tab on the bottom of the navigation buttons base.
    • While holding the tab down, lift the base of the navigation button with your other hand.
  7. Samsung 27E510C  NAV Button Replacement: step 7, image 1 of 3 Samsung 27E510C  NAV Button Replacement: step 7, image 2 of 3 Samsung 27E510C  NAV Button Replacement: step 7, image 3 of 3
    • Remove the connector wire from the defective navigation button by first gripping its connectors thumb tab.
    • While gripping the thumb tab, pull the connector from the base of the navigation button.
    • You can save the connector wire since it may not be defective.
giggythore
376 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 20
Past 30 Days: 57
All Time: 887
