Samsung 27E510C Back Panel Replacement
  1. Samsung 27E510C Back Panel Replacement, Back Panel: step 1, image 1 of 3 Samsung 27E510C Back Panel Replacement, Back Panel: step 1, image 2 of 3 Samsung 27E510C Back Panel Replacement, Back Panel: step 1, image 3 of 3
    • Use the #1 Phillips head screw driver to remove each 13.75mm length screw from the rear panel.
    • The screw alone with the ports is a different size than the rest, its length is 12mm.
  2. Samsung 27E510C Back Panel Replacement: step 2, image 1 of 2 Samsung 27E510C Back Panel Replacement: step 2, image 2 of 2
    Tool used on this step:
    Heavy-Duty Spudger
    Buy
    • Insert the heavy duty spudger in between the monitors back panel and its frame.
    • Use the heavy duty spudger to pry open the back panel.
    • Over aggressive prying could break the tabs holding the back panel in place.
giggythore
376 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 40
All Time: 1,956
