Samsung 500C ChromeBook Battery Replacement
  1. Samsung 500C ChromeBook Battery Replacement, Battery: step 1, image 1 of 2 Samsung 500C ChromeBook Battery Replacement, Battery: step 1, image 2 of 2
    • Use the spudger to remove the four rubber feet on the bottom panel.
    • Remove the seven Philips #1 screws.
  2. Samsung 500C ChromeBook Battery Replacement: step 2, image 1 of 3 Samsung 500C ChromeBook Battery Replacement: step 2, image 2 of 3 Samsung 500C ChromeBook Battery Replacement: step 2, image 3 of 3
    • Remove the seven Phillips #1 screws holding the battery in place.
    • Detach the battery connector by pulling the connector towards the battery.
    • Pull from the plastic connector, do not pull from the wires.
    • Remove the battery.
    • When reinserting the battery, it is easier to insert from the long end first before lowering the rest of the battery into place.
3 other people completed this guide.
Garrett Kissinger
704 Reputation
5 Guides authored
3 Comments
Samsung 500C ChromeBook Battery where to buy?
Uzi Naveh - Reply
I keep typing charger and all you is replacing the battery. Without a charger I can't know if the battery is bad. Can you help or not???
Carol South - Reply
Don't show my NAME
Carol South - Reply
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 15
All Time: 3,229
