Samsung 500C ChromeBook CPU Fan Replacement
  1. Samsung 500C ChromeBook CPU Fan Replacement, CPU Fan: step 1, image 1 of 2 Samsung 500C ChromeBook CPU Fan Replacement, CPU Fan: step 1, image 2 of 2
    • Remove the seven screws from the back panel of the device using a Phillips #0 screwdriver.
    • Four of the screws are under the rubber feet so they will need to be removed with a spudger.
    • Remove the back panel from the laptop.
  2. Samsung 500C ChromeBook CPU Fan Replacement: step 2, image 1 of 3 Samsung 500C ChromeBook CPU Fan Replacement: step 2, image 2 of 3 Samsung 500C ChromeBook CPU Fan Replacement: step 2, image 3 of 3
    • Use a Phillips #0 screwdriver to remove the two screws holding in the CPU fan.
    • Lift the CPU fan.
    • You might encounter some slight resistance from the thermal paste on the heatsink.
    • Detach the cord attached to the fan and attach it to the new CPU fan.
    • Insert the new fan and reassemble the device.
Enjoy your cool laptop!
2 other people completed this guide.
Garrett Kissinger
704 Reputation
5 Guides authored
One Comment
la pantalla no enciende, el ventilador arranca pero se apaga, el boton de poder da seƱal de encendido pero no enciende la pantalla
sergio rafael aguilar cantoral - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 1,008
